Old 07-09-2012, 08:59 PM   #1
Trailer: 1979 Triple e / 6cyl 09 Escape
Northern Ontario
Prpoane Furnace for 79 Surfside Triple e
My previous camper (tent trailer) had a blower fan on the propane furnace. My triple e doesn't seem to have a blower fan or else if it does it's not working properly. I have it set to 120 v on the converter and is plugged into a 120 volt house receptacle.
Is it normal for some furnaces to not have a fan and just use convection heat. I've just purchased the triple e this week.
Ed
SurfsideEd is offline   Reply With Quote
Old 07-10-2012, 10:22 AM   #2
Cam A's Avatar
Trailer: 1990 Bigfoot 5th Wheel
Ed
Yep, no fan. Advantage is that furnace is not a big power draw, nor is the fan noisy. Still throws plenty of heat.
Old 07-10-2012, 03:16 PM   #3
Northern Ontario
Thanks Cam. Good to know.
Ed
Old 07-11-2012, 03:40 PM   #4
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Smile
If your furnace is a convection heater (what make and model is it?), which it likely is if it is a 1979, then it will work with no electrical power consumption at all. Even if you have a wall thermostat like I do, it runs from a thermocouple which generates the required electricity from the flame in the furnace. So, you never have to worry about running out of battery when using the furnace, only about running out of gas.
Rick G
Rick G is offline   Reply With Quote
Old 07-13-2012, 03:26 PM   #5
Northern Ontario
79 Triple e furnace
Hi Rick,
It's a Hydro Flame Model BRC - 10A
0 - 4500 ft
Input 10,000 Out put 7000 BTUH
Pretty sure you guys are right , it's not forced air. Thanks for replies.
Ed
Old 07-13-2012, 04:49 PM   #6
mszabo's Avatar
Name: Mike & Sara
Trailer: 86 17' Bigfoot
So wht did you plug into 120v?
Old 07-13-2012, 07:49 PM   #7
Northern Ontario
I'm plugging into a 110 volt source. I have no schematic of the trailer wiring. I know the 110 volt line from (shore power) feeds the converter. There is a line coming in from the battery also. There's a thick brown wire that runs from the converter to the 3 way fridge.
When I switch over to 12 v converter setting, my interior lights all work. I haven't tried the fridge yet, but I would think it will also run on off the 12v side of the converter. My propane detector doesn't seem to work on 12v converter system, nor does the single 110/115 receptacle on the converter face.
The furnace I was just curious to know if it had a fan or not, as I was afraid it may overheat, as I notice the drawer trim above the furnace grate has melted somewhat over the years.
Think I got off topic here, but I really would like to upgrade the converter, but not sure what models are best suited to the Triple e. Reason for upgrading would be to have inverted power from the battery to the receptacle, and a smart charging circuit to charge the battery whilst on shore power.
Hope this clears up the plug in question,
Ed
furnace, surfside
Triple E surfside Brian Tin Problem Solving -- Owners Helping Owners 2 08-16-2011 02:21 AM
Triple E Surfside, Vancouver BC Emily R. Referrals: Molded Fiberglass Trailers 1 04-02-2010 11:13 AM
Just picked up a '77 Triple E SurfSide ericmarlo General Chat 2 09-03-2006 10:07 AM
Weight of Triple E Surfside TM-14's ericmarlo General Chat 2 08-28-2006 09:05 AM
14 ft. Triple E Surfside for Sale Care and Feeding of Molded Fiberglass Trailers 0 12-31-1969 06:00 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
