08-01-2007, 06:14 PM
Trailer: Class C Motorhome
hi there
I am brand new here.
I have a class c that i will be selling, and I need to buy a small light weight camper, one that i can pull behind a volvo can any one make any suggestions
thanks carol
08-01-2007, 06:15 PM
First, tell us what you Volvo's owner's manual says about 'trailer towing limits'...
08-01-2007, 07:02 PM
hi Pete
the max weight without brakes 1540
carol
08-01-2007, 07:59 PM
Trailer: Boler American (#3104)
That must be one of those new fangled front wheel drive Volvo's then! No? Sorry, I couldn't resist.
08-01-2007, 08:09 PM
Then it looks like you could tow most of the 13' fiberglass models, although not loaded with a lot of heavy options, but you certainly wouldn't have much reserve.
BTW, they don't weigh 900 lbs... That was a sort of fiction put out by the manufacturers apparently to keep them under 1,000 lbs for some reason.
You will have a lot better towing experience if you add brakes to whatever you get.
08-01-2007, 09:45 PM
Which Volvo do you have?
What does the manual say with brakes?
08-02-2007, 05:33 PM
As the manual probably explains, that weight limit has a lot of qualifications surrounding it; you need to follow all of the limits, including a limit on the total of the car, passengers, cargo, and trailer. You might find that you can only tow a 1500 lb trailer (and 1500 lb is a pretty typical 13-foot trailer when loaded) in combination with zero passengers and zero cargo in the car... which isn't likely to useful.
I agree with Frederick: with more specific information, a more useful answer can be provided.
08-02-2007, 05:47 PM
Trailer: 1978 Volkswagen Westfalia
I am assuming this is a 4 cylinder car???
Basically, you can haul your tent and all your camping gear. Maybe, a teardrop or a Puck but that is basically it.
You need to think of getting a bigger tow vehicle - at least a 6 cylinder with the towing package.
08-02-2007, 10:14 PM
Trailer: 1990 Bigfoot 5th Wheel
The rear-wheel drive 740's were rated for 3500 pounds with a 4 cylinder; apparently a tow vehicle of choice in Europe.
08-03-2007, 10:29 AM
Not necessarily. Many Volvos are not 4-cylinders, and none are very small cars. This is why the specific details are important.
