Pull a Trailer? - Fiberglass RV
Old 08-01-2007, 06:14 PM   #1
Trailer: Class C Motorhome
hi there
I am brand new here.
I have a class c that i will be selling, and I need to buy a small light weight camper, one that i can pull behind a volvo can any one make any suggestions
thanks carol
carolr is offline   Reply With Quote
Old 08-01-2007, 06:15 PM   #2
Pete Dumbleton's Avatar
First, tell us what you Volvo's owner's manual says about 'trailer towing limits'...
Old 08-01-2007, 07:02 PM   #3
hi Pete
the max weight without brakes 1540
carol
Old 08-01-2007, 07:59 PM   #4
CliveAlive's Avatar
hi Pete
carol
That must be one of those new fangled front wheel drive Volvo's then! No? Sorry, I couldn't resist.
Old 08-01-2007, 08:09 PM   #5
Then it looks like you could tow most of the 13' fiberglass models, although not loaded with a lot of heavy options, but you certainly wouldn't have much reserve.
BTW, they don't weigh 900 lbs... That was a sort of fiction put out by the manufacturers apparently to keep them under 1,000 lbs for some reason.
You will have a lot better towing experience if you add brakes to whatever you get.
Old 08-01-2007, 09:45 PM   #6
Frederick L. Simson's Avatar
Thumbs up
Which Volvo do you have?
What does the manual say with brakes?
Old 08-02-2007, 05:33 PM   #7
Brian B-P's Avatar
As the manual probably explains, that weight limit has a lot of qualifications surrounding it; you need to follow all of the limits, including a limit on the total of the car, passengers, cargo, and trailer. You might find that you can only tow a 1500 lb trailer (and 1500 lb is a pretty typical 13-foot trailer when loaded) in combination with zero passengers and zero cargo in the car... which isn't likely to useful.
I agree with Frederick: with more specific information, a more useful answer can be provided.
Old 08-02-2007, 05:47 PM   #8
Trailer: 1978 Volkswagen Westfalia
I am assuming this is a 4 cylinder car???
Basically, you can haul your tent and all your camping gear. Maybe, a teardrop or a Puck but that is basically it.
You need to think of getting a bigger tow vehicle - at least a 6 cylinder with the towing package.
Jan Adams is offline   Reply With Quote
Old 08-02-2007, 10:14 PM   #9
The rear-wheel drive 740's were rated for 3500 pounds with a 4 cylinder; apparently a tow vehicle of choice in Europe.
Cam A is offline   Reply With Quote
Old 08-03-2007, 10:29 AM   #10
Brian B-P's Avatar
Not necessarily. Many Volvos are not 4-cylinders, and none are very small cars. This is why the specific details are important.
Pull OVER!! Flygal General Chat 44 08-19-2010 10:49 PM
This would be fun...pull pet camper Ken C Jokes, Stories & Tall Tales 2 11-04-2008 12:40 PM
I had to pull over james kent General Chat 9 08-16-2006 08:35 AM
Four Cylinders Pull One Trailer Legacy Posts General Chat 9 07-26-2003 01:02 AM
Four Cylinders Pull One Trailer Rallies, Get-togethers, Molded Meets (Archive) 0 01-01-1970 12:00 AM
