Pulling with volvo v60 cross country - Fiberglass RV
Old 07-18-2019, 03:41 PM   #1
Trailer: Trillium 4500
This will be my first question for the forum. I have enjoyed reading many of the Q and A's over the past 5 to 6 years and hope someone has experience relevant to the newer volvo v60 cross country as a tow vehicle.
Presently I am towing a Trillium 4500 with my 2009 volvo v70. We have probably towed the trillium approx. 60,000 KM ( 40,000 miles) over the last several years with no problem but it is almost time to change vehicles. I've been looking at a 2018 volvo v60 cross country. Its tow specs are basically the same as the v70 but it does have a shorter wheel base. Just wondering if anyone has experience towing with a v60 cross country.
Bill
lynnbill is offline   Reply With Quote
Old 07-19-2019, 08:52 AM   #2
Trailer: Eco
Kansas
I looked it up, and the 2108 v60 has (according to my source, at least) a 2872 mm wheelbase, while your 2009 has 2816.
I think you'll be just fine.
Baxter is offline   Reply With Quote
Old 07-19-2019, 12:30 PM   #3
Thanks Baxter,
Guess I shouldn’t assume a smaller vehicle has a shorter wheel base.
All the best,
Bill
Old 07-19-2019, 02:36 PM   #4
Trailer: casita
Exclamation be careful
Ratings don't mean much. Drivers do.
Overheated, and destroyed, the transmission on my XC-90 by
1)excessive speed up hill-I-5 out of Oregon,
2)temperature over 90,
3)driver tired and wanted to get home
The numbers said the car would pull the Casita (and it did for over 10K miles).
Now I slow down (w/new tranmission)
grolympia is offline   Reply With Quote
Old 07-19-2019, 03:17 PM   #5
Good advice Gary
Do you mind me asking the year, engine and tranny for your XC90?
Old 07-21-2019, 01:12 AM   #6
Trailer: Escape 21 'on order'
T.V.
WE tow the Cassy 17' w a Frontier Dbl cab, long bd V6 w no problems except she occ drops into 3rd on steep uphills. but made for that acc to mfr
Fred762 is offline   Reply With Quote
Old 07-21-2019, 01:31 AM   #7
Whatever that means.
Old 07-21-2019, 07:05 AM   #8
Talking T.V.
It means that the mfr will list the tow capacity of yer vehicle.. in our case the 'midsize' Nissan Frontier 270 HP, V-6, long-bed, dbl cab(4 dr) truck is rated to tow 7500 lbs by the Nissan engineers..our present TT weighs in at < half that at most..easy peezee to tow.
Your vehicle has a tow rating as well. BTW the long bed does make a positive difference in towability
Old 07-27-2019, 10:50 AM   #9
Trailer: 1976 Scamp 13ft.
We tow our 1976 Scamp 13 (scale weight, loaded: 1,340 lbs, no electric brakes) with a 2005 Volvo XC70 (2.5L 5-cyl turbo, 5-speed auto, 3,300lbs towing capacity, 165K miles)
Last summer from San Antonio, Texas to central Colorado and back only about a 3,000 mile round trip but pulled several mountain passes. Plenty of power, cruised at 70 mph, averaged 19 mpg overall the whole trip, no problems whatsoever. Usually used the manual shift mode of tranny so I could control speed without overusing brakes and keep it out of high gear on the downhills.
EdBlock is offline   Reply With Quote
Old 07-27-2019, 11:44 AM   #10
Trailer: Currently Shopping
Newfoundland
I towed my Escape, 3,500 pounds fully loaded, with my 2009 XC90 which is rated for 5,000 pounds. Fine until I had to speed up on an on-ramp because a car changed lanes on a corner and was approaching too fast. I think this is what killed my transmission. Now I have a new transmission but I'm afraid to tow my trailer and wreck the transmission again. That's ok though - I found a wonderful site (Seal Bay RV Park, Vancouver Island) and I want to stay here. The mechanic who put in my new transmission told me he's seen a lot of 10-year old Volvo's that need a new transmission. My advice: accelerate slowly.
Barb Hunt is offline   Reply With Quote
Old 07-27-2019, 04:09 PM   #11
Trailer: Airstream
Connecticut
Hi Bill. I have not purchased a V60 Cross Country, but I’m interested in the car as a possible next tow vehicle.
One thing I have learned is the factory hitch for North America has a 1 1/4” receiver that uses a motorized mechanism that swings it away when not in use. It then has a 2” ball mount that attaches to the receiver. The factory hitch costs $1,500. I don’t know what the aftermarket will offer for a hitch. If you use a weight distributing hitch, it would not work with the factory hitch. The factory hitch comes with a 7 pole connector for the trailer, but it appears that the pole position for electric brakes is not wired, so you would need to a) wire your own brake controller and wire for the electric brakes or b) use one of the available wireless brake controllers.
Factory hitch for North America is listed at 3,500 lb. capacity with max tongue weight of 350 lbs. Seems like a lot for a 1 1/4” receiver. In Europe, Volvo lists the tow capacity as 2,000 kg or 4,409 lbs. for a "Braked Trailer".
Info on the hitch can be found here
https://accessories.volvocars.com/en...0AWD/Automatic
If you need a ball diameter other than 2” , you need to buy an aftermarket ball mount. The factory ball mount has the ball cast in as one piece and is not removable from the ball mount.
I can’t get info from my 2 local Volvo dealers on the height from the ground of the installed hitch to the top of the ball. If anyone here has that info, please post it.
Mike
pedalmike is offline   Reply With Quote
Old 07-27-2019, 04:25 PM   #12
I was tempted to look into a Volvo XC90 (?), but was stopped cold when i discovered it runs on premium fuel. Regular gas costs enough here in BC.
Old 07-28-2019, 03:28 PM   #13
Hi Mike,
Had the same trouble getting information on ball height for the OE hitch (from the dealer). I was looking at a 2018 v60 cross country. I called Hitch City (a franchise in Ontario) and they indicated it was not a problem hooking up a 2 inch receiver and wiring in a brake controller to the 7point connector, however if a wiring problem (ie. short) should occur it would not be covered by the volvo warranty. I suspect its' not much of a risk.
Cheers, Bill
Old 07-28-2019, 06:48 PM   #14
John in Santa Cruz's Avatar
CA
Note all those volvos are FWD (or front-wheel centric AWD) systems, the last RWD volvo was the S90/V90 in the mid 1990s. I personally would not choose a FWD(AWD) vehicle for regular towing, while it might do the job, its far more likely to fail prematurely in expensive ways as towing long distances puts a lot of stress on a vehicles drive train.
Transporting a trailer cross country Russ Foster General Chat 18 07-04-2019 10:13 PM
Cross country route advice please! FRL001 Camping, Campout Reports 38 04-10-2017 06:52 PM
Where to stop while towing Casita cross-country? whoot General Chat 30 10-27-2015 10:27 AM
How to ship a camper cross country Jane SC Problem Solving | Owners Helping Owners 5 06-28-2015 03:52 PM
Cross country "must sees" or A+campgrounds? Karen Carroll Camping, Campout Reports 13 05-20-2007 03:16 PM
