putting 15 inch wheels on a boler??!? - Fiberglass RV
Old 04-05-2011, 06:54 PM   #1
Trailer: 74 boler
hey guys
Tried to put a set of 13 inch wire wheels on my project but they are reverse offset and would not fit at all.
I'm looking at these wheels, 15 inch old school wired look, wondering if anybody knows they will fit on the boler. The bolt pattern is the same 5 on 4.5 which is fine, but stuffing it under the wheel well....will she go on? has anybody had luck with this?
thanks
thenoob is offline   Reply With Quote
Old 04-05-2011, 06:54 PM   #2
Trailer: 74 boler
Originally Posted by thenoob View Post
hey guys
thanks
(Two) 5 X 4.5 Wire Wheels with near new 165 SR15 tires
Old 04-05-2011, 07:17 PM   #3
Because of the fender skirt, you're going to need zero offset wheels. I've got 15" wheels on my Scamp, because I changed the axle to a 45 degree down. The zero offset wheels fit fine. YMMV
Old 04-05-2011, 08:00 PM   #4
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I was going to say that I took my 13" wheels off to paint them, and because my Boler rides real low I could barely get them out of the wheel well. I'm sure that 15" would not work without a new axle, but maybe 14" would work.
Old 04-05-2011, 09:42 PM   #5
james kent's Avatar
Trailer: Boler 1984
I saw a Boler with 14's that matched his early Mustang. He had to cut the wheel well opening a bit larger but it looked right with the larger tires. You may have to add spacers to raise the body from the axle so that the tires don't rub up under the wheel well.
Old 04-06-2011, 08:58 AM   #6
Trailer: 74 boler
ya seems like a little too much at this time
I think ill just powdercoat the wheels that are on there, red, and slap come old school mooneys hubcaps on her....for the time being untill i sort it out.
Sucks i dont want to get a new axle and such at this time....really wanted these wheels to go on tho, i wonder if these standard wheels in 13 inch would fit
Old 04-06-2011, 09:05 AM   #7
But, then maybe you'd delay a new axle for waaaay to long just because you like the 13" wheels that you bought... unless that's what you wanted to stay with....
Old 04-06-2011, 09:30 AM   #8
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Hay Noob!!
....just another 'idea' for you. Does this wheel/tire combo look like it might strike your imagination??
Old 04-27-2019, 09:25 AM   #9
Trailer: boler
I know this is an old post, but what are the rims and tires?
Nancy F is offline   Reply With Quote
boler
14 inch tires on S13? adimiro Care and Feeding of Molded Fiberglass Trailers 13 11-04-2011 07:51 AM
3/4 inch thick shower mat? Thane Problem Solving | Owners Helping Owners 1 03-24-2011 05:59 AM
Dexter 10X2.25 inch brakes. Perry J Care and Feeding of Molded Fiberglass Trailers 1 07-16-2010 08:19 AM
D rated 14 inch TRAILER TIRES? Bob Radenbaugh Care and Feeding of Molded Fiberglass Trailers 4 12-21-2007 10:14 AM
73 boler wheels e k maddox Problem Solving | Owners Helping Owners 1 05-11-2006 02:52 PM
