Question about 1980Trillium1300 frame - Fiberglass RV
Old 03-15-2013, 12:22 AM   #1
Trailer: 1980Trillium 1300
...Hi, I am a new member of this forum and really need help into my frame. After pulling out the frame, inspecting every inch of it with..a magnified glass, the frame seems to be in good shape, only minor rust outside of steel. The problem is the axle seems to be upwarded from ground...RIGHT AT THE MIDDLE PORTION. I kind of doubt about it's shape due to it's symmetrical bend. In my opinion, it could be original design from manufacturer. I never own any trailler camper before so please give me input, I am really appreciated. You coud see it in following picture before I start working into re-inforcement of my frame. Thanks.
Old 03-15-2013, 02:42 AM   #2
GPJ
Trailer: Looking
Many trailer axles are built with a positive camber which allows the trailer to track better - I believe that is what you are seeing here.
GPJ is offline   Reply With Quote
Old 03-15-2013, 03:51 AM   #3
Raz
Raz's Avatar
Vermont
Hi Randy and welcome to the forum. Your axle looks just like mine except I have brakes. Since you have the flanges for brakes you might want to add them. Raz
Old 03-15-2013, 06:23 AM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
That "bend" is built into the axle. Just as a side note, NEVER jack the trailer up by this piece, as it could change that built-in angle.
Old 03-15-2013, 06:34 AM   #5
Roy in TO's Avatar
It is normal. Now is the time to consider changing the axle. The rubber hardens over the years and you lose both the spring and shock benefits of a torsion axle. As Raz says, adding brakes is a good idea.
Old 03-15-2013, 10:30 AM   #6
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
As stated before, the upward bend is normal. However, when the frame is flipped over, do the trailing arms for the wheels also stay pointed upward? If so, your axle is probably past it's prime and you may want to think about replacing it. The original specs on the Trillium axle call for a 0 degree (level) inclination on the trailing arms. If you do replace it, as stated before, you also may want to consider adding brakes!
Also, Trillium built their frames pretty stout. The only reinforcing you may need to add is on the bottom of the frame where the front bolts come through. (Unless you really have a hankering to do some welding) There was a recall on the frames as certain ones may crack at that location. Can't tell from you pictures if this has already been done. Search the forums for "Trillium Recall" for more info or post a pic of the front bolt area.
Ahhhh!....More food for thought!
Spanke
Trilliums Rock!
Old 03-15-2013, 11:38 AM   #7
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
The recall on Trillium frames was for 1973-76 1300's....I'm pretty sure that subsequent (all) models came from the factory with the welded-on gussets already installed.
They show in the image below as double-pointed plates on the tongue near the upward swoop.
Francesca
Old 03-15-2013, 05:52 PM   #8
...Thankyou so much for your feedbacks. I've learn a lot from this forum. Thru your info, I have a peace of mine for my frame. When it's is flipped over, the trailing arms are downward. I would like to replace the new axle any how but not for now( maybe the next couple years) because I rarely go camping far from home more than 100miles. BTW, in particularly brake issue like Raz said, I guess it must be electric brakes. If someone could post a photo of them it would be nice and pls show me ...where to shop them? Thankyou all.
Question(s) about a frame-off Restoration Frederick L. Simson Problem Solving | Owners Helping Owners 3 11-20-2012 10:24 PM
Removing frame from 13' boler...one question... thenoob Problem Solving | Owners Helping Owners 11 10-08-2010 07:09 PM
Burro frame and axle question Mike Magee Towing, Hitching, Axles and Running Gear 5 08-06-2010 10:41 AM
Frame Paint Question DannyH Problem Solving | Owners Helping Owners 4 11-05-2009 06:16 AM
another frame question Bill D Problem Solving | Owners Helping Owners 6 02-19-2009 11:35 PM
