Question about Robertshaw replacement furnace valve - Fiberglass RV
Old 10-10-2015, 02:27 PM   #1
Trailer: 1975 Boler
Nova Scotia
Hi All, I just received a new Robertshaw valve for my furnace. I cross referenced the original duo therm number 41-0475 to 710-501 (robertshaw) but after receiving the new valve there is no where to screw my thermopile into? The place where I think it should screw in has a wire connector there (the wire that runs from the t/stat hookup area to the top of the valve. My original valve had a wire running from there but went inside the valve. I am thinking I need to purchase and install a thermopile with electric leads instead of the coaxial cable type that is presently being used? Any help or suggestions would be greatly appreciated!
Roy S is offline   Reply With Quote
Old 10-19-2015, 07:22 AM   #2
Trailer: 1975 Boler
Nova Scotia
Turned out it did need a two lead thermopile, had more issues so I gave up and ordered a Olympian Wave 6 catalytic heater, much more efficient so I have read, unfortunately wasted almost $400 trying to get the old clunker going, they do say live and learn and I learned not to bother trying to fix something you can't get proper replacement parts for.
Old 10-19-2015, 09:32 AM   #3
David Tilston's Avatar
Roy,
I am sorry you have had a bad experience with servicing your furnace. I am not sure you got the correct valve. It is my understanding that the valve in a Trillium 4500 is a 41-0640.
http://www.fiberglassrv.com/forums/d...kchart1of2.pdf
This is for both the 1300, (65810-2) and the 4500 (65512-2) version. The 1300 orifice is part number, 41-0450. The orifice for the 4500 version says NLA (no longer available). I am assuming that the orifice is in the burner, so not an issue.
This Robert Shaw valve claims to be the direct replacement for the 41-0640:
Robertshaw® 710-201 Unitrol Gas Valve 710 Series 7000SLC Right Valve® Equivalent
Well not exactly direct. The ports are in different places, so some tube bending would be required to install.
Trillium / Outback replaced the valve on my first 4500, and did a bunch of other stuff, on my furnace. But, since I have six Trilliums, (all will have a furnace) and at least one of my 4500's needs a new gas valve, I will also be attempting this procedure.
Old 10-19-2015, 01:58 PM   #4
Trailer: 1975 Boler
Nova Scotia
Hi David, sent you a PM
furnace, trillium
Gas Valve for Wagonmaster furnace J Martin Problem Solving | Owners Helping Owners 4 05-17-2016 05:13 PM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
dump valve - leak at knife valve Doghaus Problem Solving | Owners Helping Owners 3 09-29-2011 11:30 AM
Suburban heater - Gas valve question Todd Russ Problem Solving | Owners Helping Owners 1 02-17-2010 09:10 AM
Relocated dump valve Mike Taylor Modifications, Alterations and Updates 3 11-14-2005 03:26 AM
