Question: Charge Controller to Batteries - Fiberglass RV
Old 07-30-2014, 11:53 AM   #1
Trailer: ParkLiner
Virginia
I have 2 batteries connected in parallel.
The cables coming from the charge controller will come through a hole I just drilled on the left side of the batteries near the top. Can both wires be connected to the battery on the left? I'm assuming as long as I connect negative to negative and positive to positive, it doesn't make any difference which battery I connect to.
Huck is offline   Reply With Quote
Old 07-30-2014, 01:26 PM   #2
David Tilston's Avatar
I agree with your reasoning.
Old 07-30-2014, 02:20 PM   #3
Yes it will work as long as you connect positive to positive and negative to negative. Now for yabut. It is recommended though not necessary that connection from a multiple battery system be made cross battery. That is negative one one of batteries in the case of two batteries and positive on the other battery. This would be true for both charging and powering the trailer. The reason is that if becomes much more obvious if the connection between the batteries fail. Otherwise it doesn't matter.
Old 07-30-2014, 02:49 PM   #4
Trailer: ParkLiner
Virginia
Thanks. In the pictures I have found, they were usually connected cross battery, but I didn't think it had to be that way. Byron, your explanation makes perfect sense. If I can go cross battery, I will, but my cables may not be quite long enough.
Manual for EWC-10 charge controller? BCPaul Problem Solving | Owners Helping Owners 1 07-16-2011 09:07 PM
charge controller theresa p Problem Solving | Owners Helping Owners 3 05-30-2009 07:11 PM
Solar Charge Controller Installation kevin61 Modifications, Alterations and Updates 3 02-22-2009 09:20 AM
Solar charge controller yvonne Care and Feeding of Molded Fiberglass Trailers 24 06-26-2008 05:46 AM
Fluid, Battery Levels & Solar Charge Controller? peterh Electrical | Charging, Systems, Solar and Generators 9 04-27-2007 04:45 PM
