05-10-2013, 03:07 PM
Quebec
QUESTIONS on Trillium Ensolite removed.
Hi,
Here is a picture with the Ensolite rip off.
But there's residue of the backing.
The question is "Is there a trick to remove what's left?
Maybe their's a liquid cleaner that will help to do the job.
But witch one ?
Is it a good Idea to put something else under the new ensolite to add insolation?
If so What?
Is there a place in or near Montréal where I can buy ensolite.?
Thanks so much
Lou
05-10-2013, 03:38 PM
Trailer: '78 Trillium 4500
Hi, "I"...
This is no help at all, but I simply have to ask:
Is this the trailer pictured in the thread at this link? If it is...did you tear out all the Ensolite, and if so, may I ask why?
Francesca
05-10-2013, 03:47 PM
Quebec
Originally Posted by Francesca Knowles
Hi, "I"...
Francesca
Yes , I rip it off because it was rip at some places, and their was moisture
behind it.
05-11-2013, 09:14 AM
Trailer: 73,75,78 13' Boler 78 17' Boler
Acetone does work to remove the residue. Just be carefull as it can wreck the fibrglass
05-11-2013, 10:23 AM
Trailer: 2007 Casita
Why not scrape off/ sand off the big chunks then proceed with new installation?
If I remember correctly Trillium still sells ensolite! Just contact them to purchase it. They should be able to recommend what to use for added insulation as well.
http://www.trilliumtrailers.com/
Or, http://www.trilliumrv.com/
05-14-2013, 12:31 PM
behind it.
What do you plan to replace it with?
05-14-2013, 06:39 PM
Quebec
I'm still searching . Do you have suggestions?
Instead of plywood replacement around the windows, could it be replace
buy oak or maple ??
05-14-2013, 06:53 PM
Trailer: 1978 Trillium 1300
Cumberland, Indiana
I.
Welcome to the forum.
My suggestion would be to maybe slow down a little bit and do some searches on the forum for Trillium renovations. There is a vast wealth of knowledge contained here.
Good Luck with your renovations!
Spanke
Trilliums Rock!
05-14-2013, 07:09 PM
Once most of the ensolite is scraped off a twisted wire wheel brush on a 4" or 4.5" grinder is the best to get off the remaining foam residue.
Eddie
05-14-2013, 07:52 PM
Ryan just completed the ensolite replacement on his Trillium Sportsman and it cost him (with glue) about $1,500. He bought the ensolite from TrilliumRV.
05-15-2013, 09:25 AM
Instead of oak, or maple, I think I would replace the frame around the windows with marine plywood. I would also paint it with a good paint.
