radial cracking around rivets - Fiberglass RV
Old 03-07-2014, 04:58 PM   #1
I just started looking at fiberglass trailers for sale, and I went to see a '75 Boler today that is in pretty good shape. New frame, interior almost completely redone, new appliances....
I have a question about the shape of the fiberglass though. Around a lot of the rivets on the outside, there are small radial cracks. Is this a big repair job, or something to be expected for a trailer this age?
skedius is offline   Reply With Quote
Old 03-07-2014, 05:14 PM   #2
Trailer: 2010 Scamp 16
Any pictures? Any way to tell if the cracks are surface or into / through the fiberglass?
Gel coat gets less flexible with age faster than the fiberglass so flex or stress that won't harm the fiberglass can cause the surface gel coat to get fine cracks. On the other hand over stress or overloading the rivet can cause the same crack pattern down into the structural fiberglass. That would be more of an issue.
Old 03-08-2014, 09:15 AM   #3
Roy in TO's Avatar
If it is like this, it is pretty normal on an older trailer. The gel coat is not as flexible as the fiberglass. Typically called spider cracks because they look like part of a spiders web.
Old 03-08-2014, 05:23 PM   #4
The spider cracks seen in the photo Roy in TO posted a indeed a pretty common sight around rivets on many of the old Bolers that attend our meets here in BC.
PLAS-T-COTE Alkyd Fibered Roof coating cracking up stephonze Problem Solving | Owners Helping Owners 8 05-30-2012 02:21 PM
bias ply or radial tires Mr.Gauch Towing, Hitching, Axles and Running Gear 14 10-26-2011 12:28 AM
New Tires: Radial vs. bias opinions? MikeCM Towing, Hitching, Axles and Running Gear 3 10-28-2009 10:58 PM
Bias vs Radial Tires Adrian W General Chat 26 04-08-2007 04:23 PM
cracking a burro Jason L. Problem Solving | Owners Helping Owners 8 01-25-2006 10:35 PM
