Rain running down between awning and trailer - - Fiberglass RV
Old 08-31-2010, 10:45 AM   #1
Does anyone have a cleaver way to prevent the rain from running down the side of a Scamp? There is a gap between my awning and the trailer, when it rains he water just runs down the side of the trailer under the awning, so essentially nothing stays dry under the awning.
Any good ideas?
Thanks,
John
John Carter is offline   Reply With Quote
Old 08-31-2010, 11:38 AM   #2
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
John, I cannot take credit for this idea as Floyd was the person that showed it to me. However, I've "installed" it and it works like a charm. Measure the length of your awning and the distance between the trailer and the awning. Go to your favorite home improvement store and buy a piece of white "pvc" pipe with a large enough diameter to fill the space between the awning and the trailer. Cut the pipe to the proper length and use a good quality silicone to "glue" the pipe to the trailer and the awning. Now you have a filler in place that allows you to have a water tight seal between the awning and the trailer. Works like a charm, we did it 4 years ago when we bought our new Scamp and it's still nicely sealed. Good luck! Ron
RSchleder is offline   Reply With Quote
Old 08-31-2010, 11:42 AM   #3
Tom U's Avatar
Trailer: Fiber Stream 16 ft
Originally Posted by John Carter View Post
Any good ideas?
John,
Check this out. RVgutters
You could run a strip along the top and channel the water away.
Tom - '79 Fiber Stream
There is no such thing as an all black cat.
Tom U is offline   Reply With Quote
Old 08-31-2010, 11:57 AM   #4
Originally Posted by Tom U View Post
John,
way.
Tom, seems to me you need to be able to seal two seams ( trailer to seal and awning to seal) in order to stop water from running between the trailer and the awning. This product looks like it will attach to either the trailer OR the awning---what do you do with the "other" seam? More double sided tape?
Old 08-31-2010, 11:57 AM   #5
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
As a temporary solution I have seen swimming "noodles" stuffed between the shell & awning...
Old 08-31-2010, 12:48 PM   #6
John,
I've used these RV gutters, or EZE gutters, around every window to channel water away. They stick really well, and are quite flexible. My only suggestion is, if you're using it for the length of the trailer, have the middle be a couple inches higher than the ends so water runs off quickly.
ThomasE is offline   Reply With Quote
Old 08-31-2010, 12:53 PM   #7
Thanks -
The gutters look like a good solution, what did you clean your trailer with before sticking them on?
Thanks,
John
Old 08-31-2010, 01:26 PM   #8
I used denatured alcohol, but you could probably use anything that doesn't leave a residue.
Old 08-31-2010, 06:24 PM   #9
Tom U's Avatar
I'm not familiar with how your awning is attached. We don't have one...
My thought was if the space between the trailer and the awning roller was too wide to be filled with a non-silicon sealant then a gutter would channel the majority of the water away and possible overhang the gap enough to eliminate it altogether.
It was just a thought.
Good idea on raising the center of the run.
Look forward to seeing your solution,
Rain Crow Adrian W General Chat 4 06-05-2009 12:23 PM
Rain guard for 13' Boler Matt D Classified Archives 4 04-19-2009 11:43 AM
Canvas awning leaking in rain...HELP!!! Dave Baston Problem Solving | Owners Helping Owners 9 08-29-2008 05:18 PM
Trailer Running Lights Darwin Maring Problem Solving | Owners Helping Owners 0 12-25-2006 06:52 PM
Escape Trailer Rock Guard Rain Strip Thane Modifications, Alterations and Updates 3 06-11-2006 05:07 PM
