Raising Bigfoot for more clearance?? - Fiberglass RV
Old 06-12-2007, 05:36 PM   #1
Trailer: 29 ft Arctic Fox and 17 ft Bigfoot
Hello, I'm a fairly new member of this forum. I have recently purchased a 1994 17.5CB Bigfoot travel trailer. This trailer will be towed over the road mostly. Also on gravel roads and some unmaintained roads. I would like some add'l. ground clearance. We are planning an extended Alaska trip next year. Is it feasible to rotate the drop axle 180 degrees to attain more ground and trailer body clearance? Thanx in advance for any help this forum may extend!
Tom Myers is offline   Reply With Quote
Old 06-12-2007, 06:14 PM   #2
Brian B-P's Avatar
It's possible, but I don't think it's a very good plan. I can't remember what the drop in that Bigfoot is, but it's likely the same as my Boler, which has a 4" drop. Flipping the whole thing over (even if the springs stayed on the same side of the axle tube, e.g. still below the tube), would take the tube from 4" under the hub to 4" above it, a huge 8" rise. There are couple more issues:
  • the spring perches would rotate as well, so you would either need to do a spring mount conversion, or get another roughly 4" of height change due to having the springs on the other side of the tube
  • if the axle has a deliberate bend to it (normally bent up in the middle, so that is goes straight under load), then the bend will be the wrong way up.
The best way I know of to gain a few inches with a drop-beam leaf-spring axle is to replace the beam with a straight one. You can reuse all of the hub and brake components, and the springs, if you want. This has been done before by others members:
  • Dan Quinn (Amerigo)
  • Rob S. (Boler 1700)
see the topic NEW AXLE for some discussion.
Old 06-12-2007, 07:05 PM   #3
Trailer: 2000 Bigfoot 17 ft (15B17CB)
Tom,
No, you should not rotate the axle 180, trailer axles are cambered (bent upwards in the center) to become more straight under load and keep the tires reasonably perpendicular to the road. Rotating the axle will cause the axle to sag and the tires to lean in too much at the top. I assume you still have a 4" drop axle under your '94, reversing this, besides being potentially dangerous, would probably raise the trailer 9 to 10" and put severe loads on the springs.
What you can do is relocate the spring perches from the bottom of the axle to the top. This will raise the trailer close to 5", and even allow the fitting of larger and taller 15" wheels and tires for more clearance. Dexter manufactures a conversion kit for this, part #K71-384-00, or you can buy spring perches from a trailer shop and have them welded on the top of the axle. The only major disadvantage to this is that the drop axle tube will hang down well below the wheel centerline.
A replacement straight axle mounted underslung would give a 4" rise with 4" more clearance under the axle, but if you really want the trailer sky-high you could go for a straight axle with the springs on top (overslung).
Relocating the perches from the bottom to the top of the axle has been described as "flipping the axle", an unfortunate term that often leads people to mistakenly believe they can just remount the axle upside down.
Off the topic, I am a bit curious why you refer to your '94 as a 17.5CB, as the 17.5 foot was not manufactured until 2005. The earlier 1500 series trailers were deemed 17 footers, even though the actual length was closer to 16' 7"
Have fun with your Bigfoot!
Steve.
Steve C. is offline   Reply With Quote
Old 06-12-2007, 07:18 PM   #4
Yves Pelchat's Avatar
Trailer: Bigfoot 17 ft (15B17G)
Quebec
Hi Steve;
Glad you chimed in on the subject.
As you went through the steps of replacing your Bigfoot's axle, we, Bigfoot owners, are listening!
Yves.
Yves Pelchat is offline   Reply With Quote
Old 06-13-2007, 06:42 AM   #5
Hi Steve;
Yves.
Thanx for the pertinet info on raising my Bigfoot. Perhaps I will opt for an axle replacement for safety sake. By the way, this unit already has 15" wheels and 225x15" tires on it. The tires, IMHO, are dangerously close to the skirts. Steve, I listed my Bigfoot as a 17.5 as this is what is on the registration. The lady that I purchased it from listed it as a 17.5CB. You may be correct as stated. If so, I stand corrected.
Old 06-13-2007, 11:17 AM   #6
Brian B-P's Avatar
About the model designation:
Is it possible that this trailer is a 1995 15B17.5CB, and it is the year, not length, which is incorrect? Tom, if you post a photo I'm sure the Bigfoot owners will be able to tell which one you have.
Old 06-13-2007, 04:10 PM   #7
Pete Dumbleton's Avatar
One thing to remember if anyone does relocate the springs from under to over on an axle is to install a bumper or stop so that the springs can only flex as much as they did before being moved, otherwise they may flex beyond their design and break (been there, done that). Dexter has a note to this effect in their under/over-slung kit.
BTW, one result of doing a "spring-over" is to raise the underside of the trailer which will lessen or remove the air dam effect between the truck and trailer and result in less wind resistance when towing, despite the higher profile on top. Of course, the center of gravity of the trailer is also raised, so caution must be used.
Old 06-13-2007, 04:29 PM   #8
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
...and you will have to buy longer jack stands and/or scissor jacks... You will probably also have to buy a different hitch insert as well...
My 1700 has had a spring-over and I actually like it so far ... Though, as noted in another thread, it needs shocks now.
Herb P is offline   Reply With Quote
Old 06-13-2007, 05:04 PM   #9
Brian B-P's Avatar
It seems that the "air dam" improvement assumes the trailer, before modification, has less ground clearance than the tow vehicle. While that may well be the case for many, my stock B1700RGH sits at least as high as the van towing it... and it towers way above the van roof. Every bit I might raise that trailer means a bit taller wall being pulled through the air - not something I expect to be a net improvement. It may well be a different matter for Tom, who is likely towing with a truck - right, Tom?
I think the aerodynamic effects of trailer height are dependent on the specific trailer/tug combination.
Old 06-13-2007, 05:29 PM   #10
[quote]
It seems that the "air dam" improvement assumes the trailer, before modification, has less ground clearance than the tow vehicle. While that may well be the case for many, my stock B1700RGH sits at least as high as the van towing it... and it towers way above the van roof. Every bit I might raise that trailer means a bit taller wall being pulled through the air - not something I expect to be a net improvement. It may well be a .
I am towing the 17CB Bigfoot with an '01 F-250, 7.3L, 4x4 diesel P/U. This truck has a cab high topper on the bed. BTW, I/we also own a 29' Arctic Fox travel trailer that we have towed all over the U.S. The fuel mileage at best has been 10.5-11.0 mpg. I do not think that my 17' Bigfoot is really going to affect my fuel mileage as the Arctic Fox has. It may bring the mpg down to 12-15 mpg. But, that is that! Now, I e-mailed Bigfoot Industries for info on what they call flipping the drop axle. According to them, this is a viable option, said it is common. I am now somewhat cautious given this forums experience with these trailers. I do have the skills, tools and ability to rotate the axle. But again, I am now somewhat cautious. This will require some study. I will weigh the safety and ground clearance gain from flipping as opposed to a springover modification. If I do the springover I would fabricate shock mounts and install a good set. Again gentlemen, please chime in on this latest info that I have rec'd. from Bigfoot Ind.
Old 06-13-2007, 05:36 PM   #11
As for posting a pic of my '94 Bigfoot. I am much more adept with a welder and cutting torch than this blasted 'puter. My skills are with steel, fiberglass and a set of wrenches. So, if someone could post a pic for me I would e-mail it to them. Thanx greatly for all input thus far.
Old 06-14-2007, 11:57 AM   #12
Brian B-P's Avatar
...So, if someone could post a pic for me I would e-mail it to them.
Sure. Tom, I have sent you message (you'll see it in your control panel) with my e-mail address; send a photo there and I'll post it.
Old 06-14-2007, 12:06 PM   #13
Brian B-P's Avatar
I would be surprised if Bigfoot Industries really meant rotating the drop axle beam when they say "flipping the drop axle" - my guess is that they mean springover conversion - but I suppose anything is possible. I have not been able to get any technical information from them in e-mail queries - although offers of plant tours and marketing material are no problem - so I suppose I'm biased.
I've seen dozens of Bigfoot units in this size range on the road, and I've never seen one that looked high enough to have an axle rotation.
Old 06-14-2007, 12:16 PM   #14
I have made a decision to do a spring over modification on my Bigfoot. I did some measuring and put a lot of thought into the outcome of rotating the drop axle, flipping as suggested by Bigfoot, or a spring under modification. I am of the belief that the spring under is the safest and most expedious method. I will order the Dexter kit this afternoon. Brian, I will take pics soon and e-mail them to you. To all I thank you for your valued suggestions and input.
bigfoot
Raising one bench Dave Bese Problem Solving | Owners Helping Owners 1 05-27-2010 10:21 PM
Snow tire chains / Bigfoot 17CB wheel clearance breid19 Towing, Hitching, Axles and Running Gear 9 02-17-2010 10:18 AM
Raising 17' Boler sarah j Problem Solving | Owners Helping Owners 0 06-10-2009 03:17 PM
Raising a Bigfoot Peter DBK Modifications, Alterations and Updates 16 09-09-2008 05:06 PM
Raising a Casita SD16 Steve Rosenberg Modifications, Alterations and Updates 8 11-26-2005 10:54 AM
