Raising Trailer - Fiberglass RV
Old 05-13-2014, 09:44 AM   #1
Trailer: amerigo
Raising Trailer
Hi there! I am the proud owner of a 73 Amerigo. I'm thinking it's a tidge too low and my father is chomping at the bit to have it raised.
I'm still fairly new on this sight and can't seem to perform a search that touches on this.
Does anyone have recommendations? Have you heard of doing a spring over?
Any & all input is greatly appreciated.
Kindly,
Terina
tda513 is offline   Reply With Quote
Old 05-13-2014, 10:24 AM   #2
Trailer: 2014 Escape 21, Lil Joe
I thought the Amerigo had a torsion axle. Dexter has excellent documentation on their axles. For your weight you would use a Dexter Torqflex #10. You can order them with up to 3" perches and you can get different swing arm angles for different heights.
Eddie
Old 05-13-2014, 10:28 AM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Originally Posted by tda513 View Post
Hi Terina
Axle 'flipping' is very common, as is re-aching the suspension (IF you have 'leaves!). IMHO: best done by a suspension shop. One thing to remember is if you do raise the trailer's height you should also raise the tow ball (receiver, if you have a slide in one) height, keeping the trailer fairly level while being towed makes for a much nicer trip.
Old 05-13-2014, 11:53 AM   #4
John Linck's Avatar
Madison, Wisconsin
I raised my Scamp 13 by 3 inches with a bolt on kit from Perfect Casita. Easy install worked well and tows the same with a bit less worry about driveway ramp bottoming, losing underneath plumbing, etc. I raised the ball too. Perfect Casita folks were a pleasure to do business with.
John
John Linck is offline   Reply With Quote
Old 05-20-2014, 07:28 PM   #5
Trailer: amerigo
Thanks all for your helpful info! I will tell dad!
Terina
Old 05-20-2014, 07:46 PM   #6
I'm looking at a sales brochure for the 1973 Amerigo and it indicates that overall height is exactly 7' 0". The Amerigo design is a much lower profile than most so is the problem that it is lower than it was when new or do you just want more ground clearance, or both?
The sales sheet mentions "Torsion Bar suspension", "Rubber mounted torsion bar suspension" and "an independent rubber mounted suspension system, identical to the ones used on the largest and most expensive travel trailers". With those descriptions, as I could only guess what's there, you might take a look and tell us what you find so we can offer more suggestions.
But to repeat, the stock Amerigo rides much lower than most other FGRV's, the kick-up in the front frame sorta attests to that issue.
Old 05-20-2014, 08:25 PM   #7
Roy in TO's Avatar
With that info, they can measure the current height and see if the torsion axle has settled.
Old 05-20-2014, 08:31 PM   #8
carlkeigley's Avatar
NE Oklahoma
BAMA (Herschel) raised his Snoozy 4 inches.
http://lilsnoozyclub-com.webs.com/apps/forums/
Bottom of page.......
Old 05-21-2014, 12:59 AM   #9
Trailer: 1980Trillium 1300
Unless for serious enthusiastic fans to raise trailer for off-road hobby, the original design include stability and safety. When gravity plays as factor, raising trailer frame higher is seriously involved technical aspects...Just my thought...
Old 05-21-2014, 07:26 AM   #10
Timber Wolf's Avatar
North Florida
And you have to step up and down more everytime you mount and dismount the rig. All while trying to turn sideways to get through the smallish door. What I want is some air bags like the slammer kids use to lay their rides on the ground. Bouncing would optional. Humm, I have just given myself an idea for my ultimate retirement trailer.
Raising one bench Dave Bese Problem Solving | Owners Helping Owners 1 05-27-2010 10:21 PM
Raising 17' Boler sarah j Problem Solving | Owners Helping Owners 0 06-10-2009 03:17 PM
Raising a Bigfoot Peter DBK Modifications, Alterations and Updates 16 09-09-2008 05:06 PM
Raising Bigfoot for more clearance?? Tom Myers Problem Solving | Owners Helping Owners 35 07-06-2007 11:29 PM
Raising a Casita SD16 Steve Rosenberg Modifications, Alterations and Updates 8 11-26-2005 11:54 AM
