rangetop ventline fan not working - Fiberglass RV
Old 11-26-2013, 04:24 PM   #1
Had my 98 Casita for a couple of weeks now and when I got it the ventline stove fan would not run. The light works fine though.
Since I'm home today, I went out to take a look at it.
I removed the 8x8 aluminum screen to expose the fan. After removing a couple of mud dobber nests from the aluminum tray wall, I try the fan.
It works but after shutting it off, it will not start up unless I give the fan a little touch of the blade.
I tried turning it off again and it wont start up unless the blade is either still rotating or unless after it has stopped completely, I even slightly move it before turning it on.
What can be the problem?
outdoorman is offline   Reply With Quote
Old 11-26-2013, 04:48 PM   #2
Trailer: Class A Motorhome
Sounds like it got hot because it was jammed and overheated something. If it's just a bearing you might be able to apply a bit of oil and get it going on it's own.
Or it might be time for a new motor. Try finding a number on it and using Google to find a replacement.
Old 11-27-2013, 09:02 PM   #3
Try cheap first. A bit of oil on the shaft may be all it takes. I'm kinda one of those folks that works up to the expensive stuff. YMMV
Old 11-30-2013, 09:19 AM   #4
tried to remove the motor to oil but 1 of the 2 sheet metal screws holding the motor onto it's mount stripped Might try to get a replacement of it from local hardware then I will drill it out.
Old 11-30-2013, 09:59 AM   #5
Fan motors have very little starting torque so it does not take much to stop the fan from turning I would do as Donna suggested clean the fan and oil the fan motor
Old 12-01-2013, 05:52 PM   #6
thanks will try once I get it out
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Ventline range hood scamp GaryG Problem Solving | Owners Helping Owners 0 03-17-2013 10:28 PM
Fan-tastic Fan Seller - Best Price I Found barryra General Chat 1 07-11-2011 04:51 PM
ventline fan motor replacement biw314 Problem Solving | Owners Helping Owners 0 07-03-2011 08:37 AM
Fan-tastic fan Ken&Chris Problem Solving | Owners Helping Owners 13 04-11-2006 07:15 PM
