Re-greasing UHaul CT Bearings - Fiberglass RV
Old 07-03-2010, 07:36 PM   #1
KarenW's Avatar
Trailer: U-Haul CT
I had my brother-in-law come over today to help me re-grease the bearings on my UHaul CT. We were unable to break the seal. In fact, we only got one bolt loose. We retightened it and I'm going to have to have someone else do this. I have 2 questions.
1. Who would be the best to do this work? A tire place?
2. I've read several threads in which people mentioned that they had to re-grease the bearings mid trip... what are the signs you need to do this soon and the sign you need to do this mid-trip?
KarenW is offline   Reply With Quote
Old 07-03-2010, 10:21 PM   #2
Pam Garlow's Avatar
Trailer: U-Haul 1985
I'm quoting an answer that I got from someone on this forum.
"Uhaul bearings are sealed. You do not grease them... the grease in them is never changed. You don't do anything with them until they wear out, and you can tell that they are worn on inspection because they have too much free play, which is a check that should be done with any wheel bearing, sealed or not. When they are replaced, they are usually part of an assembly which bolts in. Bearings work very well and routinely last the entire life of a car which travels ten times as much as a trailer. "
When I recently had my trailer in for new tires, my mechanic said this same thing. He tested the 'wiggle' in my wheels and said that they were tight and not needing any work.
Old 07-03-2010, 10:44 PM   #3
KarenW's Avatar
Trailer: U-Haul CT
That explains the difficulty we had... Thanks.
Old 07-07-2010, 09:17 PM   #4
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
theyre very simular to whats on the rear of a mid size GM car from the eighties (front wheel drive ).
Neither is meant to be serviced and in most cases outlast the vehicle theyre on. So dont open em up unless you wanna buy new really soon.
Bruce
Bruce Thomas is offline   Reply With Quote
u-haul, uhaul
Wheel bearings Glenn Baglo Towing, Hitching, Axles and Running Gear 5 10-08-2008 07:13 PM
Wheel bearings JOE DRISSEL Care and Feeding of Molded Fiberglass Trailers 39 05-16-2006 10:57 PM
Wheel bearings. Legacy Posts Towing, Hitching, Axles and Running Gear 22 02-23-2003 04:18 PM
Wheel Bearings. General Chat 0 12-31-1969 07:00 PM
Re-greasing UHaul CT Bearings Chad S Towing, Hitching, Axles and Running Gear 0 12-31-1969 07:00 PM
