Re: Spirit bed size - Fiberglass RV
Old 06-22-2007, 12:18 AM   #1
Trailer: 1998 17 ft Casita Spirit Deluxe / Red F150 X-Cab
This seems totally silly to even ask...I'm buying a 1998 17' Spirit DL. What size sheets does the rear dinette take? I'm told it's not as long or as wide as a queen--so does that mean double? I just want to buy the right size!
Lisa M. is offline   Reply With Quote
Old 06-23-2007, 05:47 AM   #2
Administrator
Mary F's Avatar
I use kings, from an old waterbed we used to have. They're stitched together along the bottom, so I find it easier to make up the bed. (Easier is a relative term.) We keep an imitation feather bed on top of our Casita cushions. I expect a fitted queen sheet would work just fine to cover it all... I also expect a full would do the same. (The bed is NOT a standard size; besides being a little shorter and a little bit narrower, remember the two corners along the back of the trailer are quite rounded.)
Hope this bit of rambling helps!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 06-23-2007, 06:34 AM   #3
The rear bed in the SD is a standard double size. We use a double bed foam mattress from WalMart with double bed fitted sheet. It is a perfect fit (the corners are squished) for the SD rear bed. As Mary F says, Joyce also stitched the top sheet to the bottom sheet at the foot to make it easier to make.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 06-24-2007, 10:46 PM   #4
Thank you both for your advice. I figure I'll put an egg crate on top of it, just as I do at home. Glad to know my double bed bottom sheets will work! I don't use regular flat sheets, I have washable cotton duvets for my comforters, which makes bedmaking much easier.
bed size??? curtis c General Chat 1 03-04-2009 03:53 PM
Bed Size Legacy Posts Care and Feeding of Molded Fiberglass Trailers 30 01-18-2009 09:09 AM
Bed Size Rob M General Chat 8 03-26-2008 03:23 PM
The right size tow rig Gary Lynch General Chat 0 07-24-2007 09:18 AM
bed size koschnick Care and Feeding of Molded Fiberglass Trailers 10 02-03-2007 06:56 AM
