rear stabilizing jacks - Page 2 - Fiberglass RV
Old 05-15-2007, 12:57 PM   #15
Brian B-P's Avatar
Have you walked to the rear of your trailer when it`s not connected at the hitch and just sitting on the front jack?....Interesting experience! ... ......rear stands of some type are required on a regular small trailer, maybe not on a fiver which has a lot more front weight.....Benny
My Boler is a B1700[b]RGH, which has a gaucho across the back... as a result, you can't walk to the very back. Between the sheer size of the trailer (same as the B1700[b]SGH which Benny and Herb each have) and this floorplan feature, it would take a very heavy person to tilt it back with their weight, so with this model the stabilizers are not required like on a typical egg. The tongue weight is not high, at only about 10% of the trailer weight.
The jacks are still desirable for comfort, as I find it annoying having the trailer move on the suspension when anyone walks around. Like Gerry, I'm not trying to transfer any significant load, just put a hard limit on frame travel.
Old 05-15-2007, 01:01 PM   #16
Brian B-P's Avatar
We chose NOT to permamently attach rear stabilizers mainly because of the hilly terrain we live in as well as on and off various ferry slips. I'm concrened about snagging them on something back there...
I added my bolted-on jacks just behind the rear leaf spring mounts, since they are there just to take the suspension bounce. In that position, they do not drag (the rear bumper would hit first). Since the trailer doesn't tilt back even with no jacks (see my previous post), that position works fine and causes the least frame flex.
Old 05-15-2007, 01:27 PM   #17
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
There is a big difference between the capacity of screw jack to support weight, and the force that can be on it while the screw is turned.
Thanks for the clarification. I was indeed picturing a scissor jack this whole time instead of that other cheap stuff ... Had me worried because I'd just ordered 2 pairs of the BAL levelling jacks for the 1700...
I always liked the idea that if I got a flat, I could use my levelling jacks to lift the tire off the ground to change it...
I guess when camping, I'll keep the bulk of the weight on the tires/suspension...
Herb P is offline   Reply With Quote
Old 05-15-2007, 03:47 PM   #18
Trailer: Trillium 13 ft
OK, I got my bumber jacks to work... they are a bit stiff, but I guess they will loosen up with the use and vibration (and more penetrating oil).
thanks everybody for your input. Really appreciate it.
off to the next task!
Mo22 is offline   Reply With Quote
Old 05-15-2007, 04:36 PM   #19
Chester Taje's Avatar
Old 05-17-2007, 03:51 AM   #20
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
Herb, not to say the jacks will not hold up the weight of the trailer but as BP has said in this and other forums about storing for winter the trailer was desinged to carry its wirght on the tires. I know every trailer is desinged different but I know my 1300 Boler, with it's 2X4 tube frame lookes just a bit thin to fully support the whole weight of the trailer plus the wieght of 2 adults for any amount of time.
As BP stated I am sure there are some that has a frame desinged to support this but I would rather not on mine.
gerry the canoebuilder
Old 05-17-2007, 08:58 PM   #21
Robert B's Avatar
Trailer: 2004 Trillium Outback
Mo, glad you got them freed up. You'll definitely notice the difference having them in place.
Robert B is offline   Reply With Quote
Old 05-17-2007, 09:15 PM   #22
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Well, O.K. here's my present situation. I have found that where/how I stored my Trillium over this last winter has caused 'issues' with the aluminum mag wheels I have mounted. This being said, I will deal with these issues this coming season by removing the wheels n tires and storing them in my basement. Concern now is, how do I support my trailer which is under a shelter, out of the wind, rain, sleet, snow etc, but still in the elements.
Where/how do I support the egg for longer term hibernation????
Old 05-17-2007, 10:13 PM   #23
How about another set of tires on steel rims for storage to replace your mags for the winter.....or just block it up at the axle mounting point or there abouts if you don`t have to move it midwinter.....used tires on used rims shouldn`t be too expensive ......I store my trailers outside and the ends supported on stands.....my 17' trailer has a set of pull off used tires under it for the last 3 yrs....my 13' has newer tires... these tires are the ones I use in the summer .....Benny
Old 05-18-2007, 03:16 PM   #24
Doug Mager's Avatar
K L idea Benny. I still have a set (2) of the stock mags from my olf Mazda P/U with 6 plies on them. They'll bolt right on up.... Thanks a gazilliion
Scamp rear leveling Jacks length? Roger Harshaw Towing, Hitching, Axles and Running Gear 2 04-20-2009 02:23 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
Rear Jacks - Am I missing a part? Sheryl M Problem Solving | Owners Helping Owners 15 10-17-2007 10:01 AM
Stabilizing Jacks... Kurt in BC Problem Solving | Owners Helping Owners 3 07-20-2006 11:33 AM
Stabilizing Jacks Kevin W Care and Feeding of Molded Fiberglass Trailers 14 06-12-2006 10:56 PM
