rear stabilizing jacks - Fiberglass RV
Old 05-13-2007, 09:21 AM   #1
Trailer: Trillium 13 ft
Hi all,
My Tril has rear jacks attached to the bumper. apparently the old owner haven't used them, they are stuck, repainted, all rusty, etc.
we did not go out with it yet, still under make-over operations
my questions:
1- how important are they? I guess the trailer will bounce a bit especially with people using the back dining/sleeping.
2- how can I loosen them up? or should I just remove them and weld 2 new jacks?
3- other alternatives?
thanks,
Mo
Mo22 is offline   Reply With Quote
Old 05-13-2007, 10:10 AM   #2
Trailer: 74 Honey Boler
They are very important!!!
This is so timely, We have a '74 Boler in the restoration stage. I installed the new water tank yesterday and removed the front bunk. I didn't have the jacks on. While we were painting inside last night, we felt the whole trailer rotate and land on the bumper, then bam!, back on the leg up front. There are jacks under the back end now It was fine for a month, but with the new weight of the water, and taking most things out of the front was too much.
Good luck,
Jeff
J Martin is offline   Reply With Quote
Old 05-13-2007, 10:11 AM   #3
Chester Taje's Avatar
As far as i am concerned they are very usefull to stabalize the trailer.If they are a screw type jack i would try some paint remover then some penitrating oil to see if i could make them work.
Old 05-13-2007, 11:02 AM   #4
great, so I will make sure they work.
i put WD40 to loosen them up. but just in case, what's an alternative? regular jacks or wood?
Old 05-13-2007, 11:21 AM   #5
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
I've found WD40 to be largely useless... There's a good recipe for a bore cleaner that makes a great penetrating oil, cleaner, etc ...
Here's the recipe for Ed's Red Bore Cleaner
Herb P is offline   Reply With Quote
Old 05-13-2007, 11:29 AM   #6
Yeah, good idea, I will try Birchwood Casey's gun scrubber... since I already have some.
Old 05-13-2007, 01:28 PM   #7
Have you walked to the rear of your trailer when it`s not connected at the hitch and just sitting on the front jack?....Interesting experience! ... ......rear stands of some type are required on a regular small trailer, maybe not on a fiver which has a lot more front weight.....Benny
Old 05-13-2007, 04:43 PM   #8
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
We chose NOT to permamently attach rear stabilizers mainly because of the hilly terrain we live in as well as on and off various ferry slips. I'm concrened about snagging them on something back there. We chose instead to use a pair of 'loose' import car jacks (Honda in this case) so we can palce them where needed, one for either side.
I use an 18.4V cordless hammer drill (usually packed, charged in our trailer) to raise and lower the jacks. The front jack is still the manual crank, but plans this year include to 'cut the crank' and weld on a 3/4 nut in its place to raise n lower that end of the trailer. As a back up (in case the 18.4V'er dies) I have a speed handle wrench packed along.
Remember these things ar supposed to be used for stabilizing, NOT jacking!
Level the trailer with wood or commercially available wheel levellers.
Old 05-15-2007, 04:40 AM   #9
Trailer: Boler 13 ft
I installed 2 jacks about a foot under the body in the rear of my 13ft Boler last year and as said they are very important so the trailer will not tip over backwards when you stand in the rear of trailer when un-coupled from TV.
As said also they are not for jacking trailer off ground just to stabilize it so it is still important to try and park level and just do minor ajustments with them and the set up time was cut down from 45 minutes to about 15 and this is great if it is raining.
I also plan to put 2 in front of trailer so it will not be so wriggly while just raised on the tounge jack but as said...these are stablizers not lifting jacks and I try to leave most of the weight on the tires and if I have to lift one side or the other I do it with boards under the wheels.
To free the frozen jacks try PB Blaster. It is the best penertrateing oil I know of.
You may have to spray it and let it sit over night but it will loosen up most anything.
Gerry the canoebuilder
Old 05-15-2007, 05:00 AM   #10
Ed Harris's Avatar
On my 4500 I had the type that would pull out slightly and then pivot down to face the ground. Then they could slide up and down in small increments to reach the ground as long as the front jack was low. Once they were the height I wanted I then raised the front to make them touch the ground.
Anyway they were frozen in place when I got the trailer so I soaked them over and over with penetrating oil until they would move with a hammer.
Once they moved they loosened up a lot and were fine after that.
I also use those aluminum screw/platform jacks they sell all over and they even have them at Wal-Mart.
You do need something or it is difficult to live in the rig.
Old 05-15-2007, 06:49 AM   #11
Herb P's Avatar
ok. I'll bite...
Why does everyone say "these are not for jacking the trailer up"? The ones I've seen are all >5000lb capacity. In fact, the $69/pair ones at campingworld.com are 7500lb capacity. They attach to the frame the same way your spring shackles attach to the frame (with leaf springs) or, if I remember correctly, the torsion arms; and if you have 4 of them (for a 17) or even 2 of them (for a 13) then the jacks are a whole order of magnitude oversized and the frame can take it...
On my 13, I bought scissor jacks from an auto wrecker that were singularly intended to lift a corner of a whole car which is easily three times or more heavier than a fiberglass trailer ....
In fact, for winter storage, I propose that you actually want to jack the trailer up a bit to get the most of the weight off the tires...
So, I'm not seeing it... I anticipate the popular answer will be "because all the warnings say not to use it as a jack" and to that I counter "their lawyers advise them to say that because they can't afford liability insurance for a jacking application."
Old 05-15-2007, 07:42 AM   #12
Ed Harris's Avatar
Well....
I never mentioned jacking at all. In fact the stabilizers I am referring to will not jack as they can not be adjusted while on the ground at all.
I know there are both Jacks and Stabilizers that are used and they do seem to be used somewhat for the same purpose.
I beleive that the reasoning is that they are intended to stabilize the ends of the trailer only and the trailers are designed to use them in addition to the contact point of the wheels/tires.
The frames are designed to bear the weight between these points and not merely the four points the stabilizers would be used.
I have seen trailers where the frame does appear to be heavy enough to support the trailer off the wheels and I have also seen trailers where I would not even consider trying this.
ok. I'll bite...
Old 05-15-2007, 11:31 AM   #13
Con
Trailer: 1977 Boler 1300
As far as loosening up seized bolts etc. I found "Liquid Wrench" worked the best on removing all the bolts and metal work from a 100 year old horse carriage I was restoring.
I let them set for an hour and then than applied a little heat with a Butane torch. Did not break or strip one bolt! You would not believe how many bolts there where in those old carriages!
As far as jacks under your TT, Do NOT jack them off the ground, use only for stabilizing your trailer. The Bolers and Trilliums have too light a tubing frame and they will flex causing problems with you door for one thing. For those who have replaced their frame with heavier RHS tubing it would probably be OK.
Con is offline   Reply With Quote
Old 05-15-2007, 12:48 PM   #14
Brian B-P's Avatar
There is a big difference between the capacity of screw jack to support weight, and the force that can be on it while the screw is turned.
The screw jacks which come with cars (e.g. the scissors units from my Toyotas and Hondas) have a decently formed thread running in a good nut with a thrust washer between the nut or screw and the part of the jack structure it turns and bears against. The jacks labeled as "stabilizing" rather than "leveling" typically have a "nut" made from a cheap bit of stamped steel with a cheesy bit of thread cut in them, tied into the rest of the structure with two tabs roughly inserted into holes. These "stabilizers" (such as the BAL Light Trailer Stabilizer Jacks I put on my B1700) are not up to the job of having the screw turned under load. I would happily pay the couple of bucks extra for proper construction, but that construction is only available in much higher-capacity and heavier RV jacks (e.g. BAL Leveling Scissors Jack)
As for the leveling method...
As Con mentioned, there is not enough frame strength in most of these trailers to withstand shifting the load from the suspension mounts to other points, even if you do it evenly to avoid twisting. With my B1700 (which has 2" wide 4" high 1/8" thick box-section frame rails), I found that I can support it entirely at the ends of the frame, suspension hanging in the air, but it bends just enough that the door does not fit properly; put the load back on the suspension, and it flexes back to normal.
That means that if you use jacks to level, pulling one wheel potentially right off the ground (the suspension travel is under 3", and sites can be off-level by more than that from side ot side), the jack needs to be very close to the axle - not out at the end of the frame - to avoid bending.
Motorhomes routinely use leveling jacks that lift wheels right off the ground. Their frames are designed to a different standard.
I don't think that this is a liability issue, as neither leveling jacks nor stabilizing jacks are intended to support something while a person is under it.
Old 05-15-2007, 12:57 PM   #15
Brian B-P's Avatar
My Boler is a B1700[b]RGH, which has a gaucho across the back... as a result, you can't walk to the very back. Between the sheer size of the trailer (same as the B1700[b]SGH which Benny and Herb each have) and this floorplan feature, it would take a very heavy person to tilt it back with their weight, so with this model the stabilizers are not required like on a typical egg. The tongue weight is not high, at only about 10% of the trailer weight.
The jacks are still desirable for comfort, as I find it annoying having the trailer move on the suspension when anyone walks around. Like Gerry, I'm not trying to transfer any significant load, just put a hard limit on frame travel.
Old 05-15-2007, 01:01 PM   #16
Brian B-P's Avatar
We chose NOT to permamently attach rear stabilizers mainly because of the hilly terrain we live in as well as on and off various ferry slips. I'm concrened about snagging them on something back there...
I added my bolted-on jacks just behind the rear leaf spring mounts, since they are there just to take the suspension bounce. In that position, they do not drag (the rear bumper would hit first). Since the trailer doesn't tilt back even with no jacks (see my previous post), that position works fine and causes the least frame flex.
Old 05-15-2007, 01:27 PM   #17
Herb P's Avatar
Thanks for the clarification. I was indeed picturing a scissor jack this whole time instead of that other cheap stuff ... Had me worried because I'd just ordered 2 pairs of the BAL levelling jacks for the 1700...
I always liked the idea that if I got a flat, I could use my levelling jacks to lift the tire off the ground to change it...
I guess when camping, I'll keep the bulk of the weight on the tires/suspension...
Old 05-15-2007, 03:47 PM   #18
OK, I got my bumber jacks to work... they are a bit stiff, but I guess they will loosen up with the use and vibration (and more penetrating oil).
thanks everybody for your input. Really appreciate it.
off to the next task!
Old 05-15-2007, 04:36 PM   #19
Old 05-17-2007, 03:51 AM   #20
Herb, not to say the jacks will not hold up the weight of the trailer but as BP has said in this and other forums about storing for winter the trailer was desinged to carry its wirght on the tires. I know every trailer is desinged different but I know my 1300 Boler, with it's 2X4 tube frame lookes just a bit thin to fully support the whole weight of the trailer plus the wieght of 2 adults for any amount of time.
As BP stated I am sure there are some that has a frame desinged to support this but I would rather not on mine.
gerry the canoebuilder
Scamp rear leveling Jacks length? Roger Harshaw Towing, Hitching, Axles and Running Gear 2 04-20-2009 02:23 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
Rear Jacks - Am I missing a part? Sheryl M Problem Solving | Owners Helping Owners 15 10-17-2007 10:01 AM
Stabilizing Jacks... Kurt in BC Problem Solving | Owners Helping Owners 3 07-20-2006 11:33 AM
Stabilizing Jacks Kevin W Care and Feeding of Molded Fiberglass Trailers 14 06-12-2006 10:56 PM
