Rear View Camera Question - Fiberglass RV
Old 09-02-2014, 07:21 PM   #1
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
For those of you who have installed a rear view camera on your egg in order to keep track of traffic behind you and the tailgaters, did you install it above the rear window or below the rear window, and why?
Sent via Mental Telepathy directly to Fiberglass RV
Old 09-02-2014, 07:42 PM   #2
Hey Carl, you don't want to hear from me My new F-150 came with a rearview camera.. installed on the tail gate. I really wish it was mounted up on the third brake light (top of cab) instead. There's a reason HIGH wins (bigger field of vision), but it really depends on the "camera." Now, you just need to hear from folks that put one on their trailer!
Old 09-02-2014, 07:56 PM   #3
CPW
CPW's Avatar
Yea, Donna, you're right. I have a BU camera in our CR-V and I love it. But I didn't have one on the F150, only a warning buzzer that beeps more rapidly the closer you get to something. But if I did have the BU camera in the tailgate it would have presented me with a quandary...... I changed the tailgate to a "5th wheel tailgate." Don't have to drop it and raise it while hooking up. I have purchased a 2 camera system; one for the trailer and the other fits on the license plate bracket for when I'm not connected. Still not sure if I should mount the camera above or below the rear window on the camper. Response so far has been light.
Old 09-02-2014, 10:07 PM   #4
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Carl if you mount it under the window you will probably have views of grills, hoods and windshields. Mounting above the window you should get a view over the top of following vehicles for a better overall view depending on the camera recording parameters.
Old 09-02-2014, 10:12 PM   #5
Still early yet Carl for folks to post, but I remembered a camera rear window mount on a Scamp 5er, the post is a couple of years old, but maybe some of the conditions still apply... direct link: Backup Camera--Koolertron
Old 09-03-2014, 04:22 AM   #6
honda03842's Avatar
Name: Norm and Ginny
We mounted our camera in the lower corner of the rear window on the passenger's side. We choose this corner because it allows the rear window to fully open, At the same time it provides a good field of view.
We have recently purchased a new camera, yet to be installed.
Our new Odyssey has a rear camera near the rear door handle, about half way up. It provides an excellent field of view though it only activates when in Reverse.
We use the Scamp's rear camera in lieu of side mirrors. I would love to be able to tap into the Odyssey's display instead of adding a second display for the Scamp's camera.
One interesting aspect of the Odyssey is that it is the same width as the Scamp.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-03-2014, 08:14 AM   #7
fusedlight's Avatar
Trailer: 16' 1998 Scamp
I'm using a re-purposed back-up camera. It mounts right above the license plate. Not elegant, but cheap and lets me see what's what when passing (hah!) or being passed.
fusedlight is offline   Reply With Quote
Old 09-03-2014, 03:25 PM   #8
CPW
CPW's Avatar
Anybody else out there with a rear view camera who can chime in on this thread?
Old 09-03-2014, 05:11 PM   #9
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
On our Scamp I had mounted the camera INSIDE looking out through the window, in the upper passenger side corner (like Norm, I wanted to be able to open the window. On our Lil Snoozy I mounted a camera above the rear entrance door. I would only recommend a hard wired system, as the wireless systems gave poor quality pictures with much static when it did work. Good Luck with what ever you decide.
Dave & Paula
Old 09-04-2014, 01:59 PM   #10
honda03842's Avatar
Wireless
I used a wireless installation on our CRV for the trailer camera. It would very occasionally burp. It seemed that a passing vehicle would steal the transmission frequency.
It was really not too much of an issue because it was rare. Unfortunately the wireless transmitter or receiver failed. Both were located inside so the failure was not due to weather.
I tested both cameras and both displays via a direct connection and they both worked well. The new display is much larger.
My intention is to mount both cameras, one on the back of the trailer and one possibly on the front of the Odyssey. The new display has a manual switch to allow you to switch between video feeds.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-04-2014, 06:42 PM   #11
Trailer: 2013 Trillium 1300
My camera is inside the trailer at the bottom of the rear window, near the center of the trailer's rear wall. The camera image mimics the view in a rearview mirror. I am more concerned with seeing overtaking traffic than with backing the trailer. I did not need to drill holes in the trailer and the camera is more protected from damage or theft. I threaded the video cable through the existing hole for the trailer pigtail.
Terry J is offline   Reply With Quote
Old 09-04-2014, 06:44 PM   #12
honda03842's Avatar
Terry,
I don't use mine for backing up either, maybe if I was alone.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-05-2014, 10:33 AM   #13
Trailer: Bigfoot 17' DLX
Alaska
I don't have a rear facing camera yet but I've been looking into it and considering mounting locations. One thing I noticed, and this would depend on when/where you tow your trailer, is that the back of my trailer gets incredibly filthy, especially the lower half. If there was a camera mounted outside, it mostly likely wouldn't be able to provide a picture after a few hours of driving in the rail or snow or even a few minutes of dirt road travel. By contrast, my back window stays relatively clean and even when it is dirty, it's quick and easy to wipe clean. For that reason alone, I would mount a camera inside the rear-facing window.
trainjunkie is offline   Reply With Quote
Old 09-05-2014, 11:22 AM   #14
CPW
CPW's Avatar
I am leaning in that direction myself if I install one, for the very reasons you mention, as well as it would not be exposed to the elements and one less hole thru the fiberglass. I expect some image degradation/darkening from the window. But if others have different opinions or experiences, please keep them coming.
Video Back-up camera. Which one? David & Terry Problem Solving | Owners Helping Owners 6 02-28-2017 05:46 PM
Cheap Camera for Rear fusedlight General Chat 22 06-26-2013 09:50 AM
Human Camera Donna D. Jokes, Stories & Tall Tales 1 05-28-2009 02:40 PM
Rear view mirrors Ian R Problem Solving | Owners Helping Owners 42 08-16-2007 12:28 PM
Rear view mirrors Ian R General Chat 0 12-31-1969 07:00 PM
