recommendations on new interior wall covering? - Fiberglass RV
Old 02-08-2011, 11:04 PM   #1
LukeP's Avatar
Iowa
We bought our '72 Boler last spring, the previous owner had installed reasonably deep pile carpet over the entire interior. While he did a great job, we're going to replace it (previous owner had a cat, our daughter is allergic to cats. not a good equation! and I'd like something with some insulation). Over the past year, I've seen links in these forums for products you all have recommended... some similar to ensolite, etc. Now I can't find them, search as I may!
Any ideas, or experience, on where you've purchased new 'skin' for the insides of your eggs? Thanks in advance! Luke
LukeP is offline   Reply With Quote
Old 02-08-2011, 11:42 PM   #2
Trailer: Fiber Stream
Previous Ensolite Discussion
Volara - Closed cell foam for insulation
Old 02-09-2011, 06:41 AM   #3
DannyH just completed his 1976 Scamp... and it's BEAUTIFUL. At anyrate, CliveAlive asked Danny what he used to insulate the Scamp and what wallcovering. This is a direct link to that reply: Siesta is finally done, my 76 scamp
Be sure to go to the top of the first page (it's only two pages long) and look at all the pictures... gorgeous!
Old 02-13-2011, 05:16 PM   #4
Robert Johans's Avatar
Trailer: Nest Caravans
DannyH was lucky enough to be able to salvage his original ensolite.
I have replaced the "bad" insulation and wall covering on a few projects using "Reflectix" insulation (essentially silver-backed bubble-wrap, approx 1/4" thick—available at Lowes, Home Depot, etc.) and heavy duty upholstery fabric or automotive headliner material.
The Reflectix is exactly what Scamp uses in their current production models, though they use "rat fur" (hides a multitude of production flaws) as a top layer.
Old 02-13-2011, 11:19 PM   #5
LukeP's Avatar
Iowa
thank you ALL. this has been some interesting reading. I guess I need to do some more searching on how many square feet the inside of a boler is. OR dig thru the snow to get into storage and measure it! regardless, thanks a bunch for the tips.
Old 05-15-2011, 07:32 AM   #6
Trailer: Casita 16'
Wisconsin
Wall Panels
Luke,
I just received a reply from AeroParadise.comLLC. Eric tells me he used coroplast, corrugated plastic material that takes the shape of the interior walls. The upholstry fabric is then glued to the coroplast. This material is the same used in experimental aircraft interiors. It is lighter than alumalite.
mona
monasimpson is offline   Reply With Quote
Old 05-15-2011, 06:36 PM   #7
We use coroplast at work for making outdoor signs. I can't imagine bending it, other than scoring and bending to a 90 degree. It's doubtful it would mold to the corners of an egg-shaped trailer. Before purchasing a bunch, I'd get a small sample and try it for your application.
Scamp 13 wall covering Greg G. Care and Feeding of Molded Fiberglass Trailers 11 10-16-2010 02:36 PM
Wall covering on Lil' Bigfoot Peter DBK Care and Feeding of Molded Fiberglass Trailers 6 06-07-2010 06:53 PM
Captain (mold) need advice for wall covering and floor pls Elizabeth.G. Problem Solving | Owners Helping Owners 1 05-19-2009 03:05 PM
For those that have replaced the interior covering... Stacy Crotser Problem Solving | Owners Helping Owners 30 05-16-2009 07:54 PM
wall covering on trillium Lee Trenholm Problem Solving | Owners Helping Owners 21 05-27-2008 01:24 AM
