Reconfigure Trailswest Pop-up - Fiberglass RV
Old 04-06-2014, 09:30 PM   #1
teri85's Avatar
Trailer: Trails West Campster
Okay, some advice or ideas, or you're nuts to try that.
I have to take the plywood off the pop top of my trailer as there is a leak and it is coming through. I think I am going to find some dry rot. The roof is really heavy after a rain. Since I need to take the top off I have been considering making it so the sides of the top are semi-rigid. By that I mean that the ends would be 1/2 in plywood that would fold down and secure (not sure how yet). This would be to stabilize the top, which tilts to the side even when level. I am also thinking about doing the same on the sides.
So, I am looking for advice and what kind of problems I need to consider.
Thanks for all your thoughts and ideas.
Teri
teri85 is offline   Reply With Quote
Old 04-06-2014, 10:39 PM   #2
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
There are some plans around for homemade popup trailers- basically a trailer bed with plywood walls you set up. Something like that might give you a good idea how to do it on the poptop. Interesting idea. I don't think you'd want 1/2 inch plywood; 3/8 would probably be enough.
Old 04-06-2014, 11:08 PM   #3
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
If trying to keep the pop-up straight & sturdy, you could just try using small diameter stainless cable crisscrossed on one or two sides. Small turnbuckles will allow for small incremental adjustments. These could also be hidden inside a sewn in channel in the fabric. This set-up would also save some weight.
Old 04-07-2014, 07:34 AM   #4
D White's Avatar
Trailer: Trails West Campster, CampStar, Uhaul, Fiberstream
It is probably leaking through the bolts on the top...I would remove the plywood and replace with lighter paneling, seal the bolts (the only factory holes in the top fiberglass) and replace the springs...then it will work very nice......Dave
D White is offline   Reply With Quote
Old 04-07-2014, 07:40 AM   #5
I did that with webbing, but I like the cable idea. Mine will stay up level with just the webbing, no fabric.
I wonder if you could use those things that hold camper shell doors up? (Can't remember what they are called.) But you'd still have to cross-stabilize.
Old 04-07-2014, 08:52 AM   #6
teri85's Avatar
Thanks for the idea David. I hadn't thought of the cable idea. I had thought about the webbing that Bobbie has used to stabilize the top.
One of my concerns with the top is last weekend (March 28-30) in Yosemite we awoke to several inches of snow on the ground. I had lowered the top as it was raining when we went to bed. When I went to raise the top it was too heavy to comfortable push up and have it stay. Not that I plan to camp in the snow but one of my favorite places is the Sierra and Yosemite in the spring and snow is a possibility.
Dave, I think part of the leak is some PO had used silicon around some of the bolts so I will have a mess to clean up when I take it off.
eco
PopTop for TrailsWest Campster DJ Hirte Problem Solving | Owners Helping Owners 26 11-01-2011 09:14 PM
1970 Trailswest pop top & cushion issues alan H Care and Feeding of Molded Fiberglass Trailers 8 08-28-2011 08:02 AM
Mislabeled Compact[jr], Hunter, TrailsWest Campster on ebay Kenny H Classified Archives 5 05-26-2009 08:55 PM
SOLD/GONE - Free Trailswest Campster in Camarillo, CA Lisa H. Classified Archives 9 07-02-2008 05:34 PM
New TrailsWest Campster owner Gscott Modifications, Alterations and Updates 16 01-22-2008 07:41 AM
» Trailer Showcase
Boler
nickbeaver
UHaul
Calud13
