refrigerator will not run on gas - Fiberglass RV
Old 01-11-2018, 09:02 AM   #1
Trailer: 2015 Casita 17 SD
I have a 2015 Casita SD 17 with a Dometic RM2454 refrigerator. the unit works with 12V and 120V but not gas. The burner starts up but with in a minute the igniter starts firing again the the unit shuts down. I have cleaned the gas jet and it looks very clean. The stove works great and tried and tested both tanks so I probably got good gas pressure.
thanks, Stan
notnats is offline   Reply With Quote
Old 01-11-2018, 10:05 AM   #2
Raz
Raz's Avatar
Vermont
I would start with the obvious. Gas in the tank? Valve open? Next I would clean the burner, chimney, etc. Sounds like you've done that. I think this fridge has a control board which requires 12volts. I'd make sure those connections were good. . Next, I would test the thermal couple. That's all the easy stuff.
Old 01-13-2018, 09:02 AM   #3
Ohio
What model is it? Take a pic if you don't know
cmartin748 is offline   Reply With Quote
Old 01-13-2018, 09:14 AM   #4
Dometic model RM2454 as stated in line #1 of post #1.
Old 01-13-2018, 10:06 AM   #5
Ohio
Oh sorry.
Sounds like the burner needs a good cleaning. The sensor is not sensing the flame.
There are a lot of Utube videos on the subject.
http://rvrefrigeratorrepair.com/wp-c...350-RM2850.pdf
Old 01-13-2018, 01:21 PM   #6
Oh sorry.
OR the flame is just fine but the sensor is corroded or out of position or the connection is loose
When all else fails follow Raz
Old 01-13-2018, 07:09 PM   #7
Verify that you have proper propane flow. Torn off propane. Open propane valve at the bottle slowly. Now go to your stove top and light both burners and note if burners are burning properly and of proper heigth. Noting that you have good flow after several minutes. Turn off the burners. Now check your battery voltage. On some of the nerwe fridges battery voltage comes into play with their circuit boards. Make sure your voltages are over 12 volts. Check and make sure there is battery power actually getting to the fridge.
Any further than this and you will need someone who is really into fridge repairs to dig in deep to find the problem.
Old 01-13-2018, 07:26 PM   #8
Originally Posted by notnats View Post
I have a 2015 Casita SD 17 with a Dometic RM2454 refrigerator. the unit works with 12V and 120V but not gas. ..
Have the propane system checked by a professional (using manometer, etc..) and if no problems with the propane are found, check out http://www.fourwh.com/NewDometicRefrigeratorManual.pdf
Old 01-28-2018, 01:27 AM   #9
Trailer: Trail Cruiser
it's either the thermocouple of circuit board. I've replaced both on my dometic.
Old 01-30-2018, 08:38 AM   #10
Trailer: 1999 Casita 17' SD
Ohio
Oh sorry.
He did that too, stated in the third line of his post..
Gordon's suggestion about having the pressure checked is my guess.
All the appliances in a Casita have secondary regulators in them and run on a lower pressure EXCEPT the refrigerator that is totally depend on correct pressure from the main regulator on the tanks
Joe
Old 01-30-2018, 10:05 AM   #11
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Stan, check the exhaust opening for mud dobbers.
Bees like to nest in the chimney. Causing the exhaust to back up and starve the burner of oxygen.
Old 01-30-2018, 10:37 AM   #12
And thats pretty much all we can do on the forum is guess. Which is why I suggested the Diagnostic Service Manual. It lays out a logical step-by-step troubleshooting method that a technician would follow.
Old 02-24-2018, 09:06 PM   #13
Trailer: 1977 17' Boler
Saskatchewan
Hey Stan,
I am not saying that I can fix your problem, but I too had a similar experience. So this may help. Not sure.
The pressure of gas the your appliances needs to run on is about 11 inches of water column or 0.397 psi. You will need a manometer to check this or have service tech to chech this out for ya. You can see for yourself if the prssure is steady. Turn on you propane stove top burder. If the flame is steady and not dancing or jumping around, then it is likely that is not the problem. Mine was dancing and jumping in height. New regulator I thought. Same thing. Borrowed a monometer and the pressure was way down even with the new regulator. Now what. I mentioned it to my dad, who used propane to heat and cook in the house when I was a boy. My dad said did you check the gas line for oild build up. What I said, propane has no oil in it. I was wrong. Disconneted all of the appliances. Disconnected the propnae line at the front of the trailer near the regulator. Drpped the hose down and sure enough, the black started to drip. What? Ok dad now what? Let what ever will drip out, drip. Capped that end of the hose and syringed rubbing alcohol down the lines of each appliance until all of the line was full. The capped each line at the aplliance end. Since I had work to go to, I left it sit like that for two days. Opend the lower hose and, then Iopened the furthest appliance end cap and blue clean commpressed air down. Sure glad my dad suggested tying a old rag over the other end of that hose. After I blew out the furthest appliance, I recapped it and went to the next one, and blew it out and so on. Wow what alot of black sticky crap came out. Iran a little more alcohol ( not moon shine) down each line and more air.
Time to check. My dad suggest getting a small brass tee fitting and a short straight brass pipe, I thing 1/4 inch diamter and about 2 inches long witha cap and place it inline and the lowest end of the line to catch any more of the black stuff.
Reconnected everything. Turned on the gas, and soap test. All was good. Mamonoter test time. Oh good 11 inches of water column. No more flame dancing on the stove top burners. Fridge ran great. I empty that little pipe at the start of every season.
Hope this helps
Greg Boler77
Boler77 is offline   Reply With Quote
Old 02-24-2018, 09:52 PM   #14
Greg's "T" fitting and short pipe is commonly called a "drip T", used on heating appliances to catch any debris in the line. Usually installed at the appliance.
refrigerator
What can I run and not run on my home electricity? GregandTeresa Electrical | Charging, Systems, Solar and Generators 21 06-18-2016 06:16 AM
Gas Consumption Check, 1st Run Richard Hayes General Chat 8 06-27-2012 12:39 AM
Gas Consumption Check, 1st Run Richard Hayes General Chat 0 06-25-2012 12:44 PM
Just gas or gas/electric water heater? Feedback wanted. Bryan L. Care and Feeding of Molded Fiberglass Trailers 15 09-15-2010 09:11 AM
Dometic Refrigerator Doesn't Run Ted E. Problem Solving | Owners Helping Owners 11 03-01-2007 07:05 PM
» Trailer Showcase
tbd
robz5
1993 Scamp
barryra
