Regasketing Burro Air - Fiberglass RV
Old 08-13-2012, 04:42 PM   #1
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Seems the Escondido paesans were having a bad Monday when they installed my AC. Upon disassembly, I found that the roof was reinforced in the area of the AC but not correctly. Pictures of the roof opening indicate to me that 1) plywood pads glassed to exterior skin were located too far aft, or 2) pads were located to spec but the AC opening was located too far fwd., or 3) the swale in the outer skin was intentional. I can think of arguments for all three but the fact that the gasketing surface was not a true plane or "stool" as was done for the front vent in the Burro meant that even compression of the gasket was impossible to achieve. It had been tightened to the point that the gasket was completely compressed in front; barely compressed at all aft. Apparently it continued to leak as someone had added two silicone dams or levees outbd. of the gasket. The first of these was obvious when I bought the trailer and I removed it when I first began to refurb the trailer because I knew it was a hopeless lick and promise fix and removing it would reveal just how bad the leak was. Oddly I did not always get water in the inner pan in light rains but did get some in protracted rains.
I had not had the inside pan and shroud off until yesterday. I could see the smashed gasket (pic #3) so I did a bit of pricing. What I could see from the inside was the partial reinforcement and the "step" in the external skin on both sides (#5). That made me think I needed a gasket thicker in the front. I wasn't about to spend 30-40$ for two closed cell gaskets so I got the idea that the closed cell polyolefin sleeping mats sold at Walmart might possibly make a reasonable gasket. #4 is the gasket material cut into several gaskets (I did not use them all) and #9 is the assembled gasket composed to two complete half inch thick rings and a third partial ring to give the differential thickness forward of the step in the skin. These were laminated using contact cement. The partial ring was placed on top so that the continuity of the bottom layer of gasket was not affected. While removing the compresser unit on top, I discovered that the flange in front and at sides was a bit hard to break free due to a second silicone dam. This was a lot of fun to remove with putty knife, razor blade, piece of plastic laminate, Bestine and scrubbing with coarse ScotchBrite but I knew that from getting rid of the first one over a yr. ago. Fortunately, this is about the first day with low humidity and decent air quallity we've had in three weeks so I took advantage. Pic #s 7 and 8 show the gasket from inside the trailer and from left side exterior.
Checked out dry with a good flooding of water from hose. Amazingly, that "step" at the sides of the opening creates a swale fwd of the unit which drains very well over the sides of the Pullman roof. One might almost think it was intentional altho when on the scafford it looks like a case of tincanning. I think my occasional leak was more due to the silicone dams than to this sorry excuse for a gasketing surface.
In the course of flooding the roof, I also got my half a cup drip from the upper part of the clamp ring on the rear window. I was already considering rebedding it but wanted to eliminate a leak between skins as the source, which of course led me to consider redoing the AC seal.
I find it odd that flooding without a pressure nozzle on the hose is a much more reliable and consistent locator of small leaks than doing so with spray under pressure. I don't know if this is everyone's experience but it's mine.
jack
Old 08-14-2012, 08:09 AM   #2
rabbit's Avatar
Delaware
Frogstrangler this morning; still dry. Water draining awy from gasket without the silicone levees. Think I have to change the hgt and inclination of the shroud. Easy to do as it is a replacement MaxxAir which is a bit too high for the Coleman AC and has spacers on extension studs to jack it up. Take two out in the front, cut some off the threaded studs and voila! I like to use acorn nuts filled with wheel bearing grease up there as they don't rust seize easily.
jack
burro
Air conditioer installation in Cloud/Burro/U-Haul DonDeutsch Care and Feeding of Molded Fiberglass Trailers 6 07-08-2010 07:17 AM
best technique for air flow with Maxx Air Fan with 13 footer lloyd cicetti General Chat 4 06-18-2010 05:04 PM
To Air or Not to Air Butch H Problem Solving | Owners Helping Owners 1 05-12-2007 01:57 PM
air went out BAMA & Pachyderm Posse General Chat 1 08-24-2006 08:11 AM
Air conditioner Sonny Problem Solving | Owners Helping Owners 5 06-22-2006 08:13 PM
