Reinforcing Cabinet Openings - Fiberglass RV
Old 06-11-2010, 10:45 AM   #1
Trailer: Burro 13 ft
Hi again,
I'm putting in new cabinet hardware for all my doors and building a shelving unit in the closet. I wanted to reinforce all the openings by attaching high quality, marine plywood strips on the inside face of the fiberglass for the hardware to mount to and to strengthen the cabinet (essentially a face frame on the inside). Can I epoxy the wood straight to the fiberglass after I've prepared the surface? Do i need to prepare the wood in any way?
I'm using piano hinge and these safety push latches:
http://www.rockler.com/product.cfm?page=1375
Thanks
kyle minor is offline   Reply With Quote
Old 06-11-2010, 10:53 AM   #2
Raya's Avatar
Hi Kyle,
Yes, you can epoxy the wood frames in place. Some thoughts:
1) Prep fiberglass to include initial removal of mold release wax (Interlux 202), then sanding for tooth, then a final solvent wash (acetone or denatured alcohol).
2) Prep wood by sanding for tooth and then wiping with acetone.
3) Affix wood to fiberglass with thickened epoxy and clamp in place until it cures. Go for some squeeze out but do not "wring" the joint dry. that might induce warpage and also epoxy does not like a dry joint. It is amenable to gap filling.
4) I might give a quick coating of neat epoxy prior to using the thickened but that is probably not necessary for a camper.
Other reinforcement options include pre-made fiberglass board or angles (McMaster Carr - the dark green stuff), or hollow stringers or shapes such as those made by Taco or Prisma (depending on what you are doing in terms of anchoring fasteners - all options may not be suitable).
Raya
Old 06-11-2010, 11:02 AM   #3
Perfect, Thanks!
Any thoughts on reinforcing in general? I hesitate because i don't want to create a super stiff area that transfers stress to weaker areas. I specifically don't like how the double-walled Burro cabinets hang from, but are not attached to the roof. It all seams very weak, it would be nice to tie it all together by glassing the inside of the cabinet to the ceiling.
Old 06-11-2010, 03:13 PM   #4
Raya's Avatar
I hear you on that, Kyle. I've heard the Burros and U-hauls described as "double hulled," but to my mind the inside is more of a molded liner -- probably used because it is easy to put in and keep clean (not that those are bad qualities, mind you). It does attach to the shell in some places, so I'm sure it provides some support and "doubling," but certainly not as much as it could.
Also, you are right to be thinking about stress risers, point loads, etc. that you could be creating by adding stiffeners. You don't want to cure to be worse than the cause.
It's hard for me to recommend anything specific without being there to poke and prod (the trailer), but here are some thoughts, coming from experience with boats:
Actually, wait, let me back up a bit. I just want to describe how, in fiberglass boat-building, there are a few ways to provide stiffness and support (because fiberglass is inherently quite floppy). With a fiberglass boat, or camper, you want a monocoque structure, wherein the skin and the stiffness work as structureal members.
Typically in the earlier days (1960s, early 70s), The interior of a boat was "stick built" Support for the hull was given by bulkheads (transverse interior walls) that were bonded to the hull and deck, usually with fiberglass tabbing (like tape strips). Also, stringers were used (longitudinal hat-shaped supports fiberglassed to the hull).
Then in the 80s or so, builders started using pre-formed "liners." These were usually molded fiberglass, just like a shower stall or a Burro liner. They saved money (skilled labor), and time (just drop it in and you are basically done; no carpentry needed). Also, builders started using structural grids under the liners (I'm not an expert on this, but I think I have the gist). These are molded fiberglass grids (say, half pipe shapes laid out like a Tic-Tac-Toe board) that are bonded in under the liner. They provide support for the boat in combination with bulkheads (which are now often simply slotted into a groove in the liner, not tabbed). But the liner and the structural grid are not always together; you can have one without the other, such as in the case of a U-haul or Burro (at least I have never seen evidence of any structural grid).
For the deck of a fiberglass boat, usually some kind of coring/sandwich is used. Essentially, two fiberglass skins are held apart by a core material, and the tension of the skins (like an I-beam) make it strong and stiff.
So okay, where was I?
Oh yes, some thoughts about how to strengthen:
1) Core an area (like a boat deck). This would involve sticking some kind of thin core to the shell (1/4" balsa, foam, thin ply) and then fiberglassing over it. You could perhaps taper the core to make a transition.
2) Tab in a bulkhead. When boat bulkheads are installed they are intentionally left 1/2" or so shy of the hull. If they fit perfectly they would make a hard spot that would show as a bulge. The gap is often filled with closed cell foam, then fillets are made (tapered corners of something like thickened epoxy; or you can taper the foam in a trapezoid shape), and then fiberglass tabbing is applied on boat sides. The tabbing spreads the load over a wide area, and makes a solid connection. Flexing is the enemy.
3) Tab in cabinetry. In the case of a Boler type, one could tab the cabinetry in (similar to bulkheads, above) and eliminate the rivets while making a stronger shell (some people think the rivets are there to allow for flexing; but flex is the enemy and the rivets are there because they are economical to install in a production setting, and our campers had to be economically viable).
4) Stringers. Stringers are longitudinal stiffeners. They were originally wood (as were boats!), but with fiberglass they can be wood, hollow plastic, half pipe, foam... the point is to cover them with fiberglass that extends out onto the hull. It's the shape that provides the strength, typically (althoughthe wood core can be engineered to be part of it, I would say not as a rule). A stringer is pretty favorable for not making hard spots yet providing support.
So, on your cabinets, you could probably tab them to the hull on the inside (where it would not show and would not have to be overly sleek). You would just want to ascertain that you would not be creating any hard spots, or transferring a load to a component that could not take it (imagine the cabinets pulling the roof down). Now, that is not likely - after all Boler/clones are not super heavy duty, and the cabinets are riveted to the roof, but it is still something to think about (and Bolers/clones do have a "wrought iron" support from the inside edge of the upper cabinet down to the counter.
I would just say to think about where the loads and stresses will go (as you have been doing), and think about spreading any point loads. A nice wide set of tabs might very well give you a stronger more rigid overall structure (because although point loads are no good, overall rigidity is good).
Okay... still awake?
Of course that doesn't mean you can't ask more specific questions once you have sussed it out a bit more
And as always, more photos = more better
Raya
Old 07-30-2015, 10:36 PM   #5
Trailer: 1973 Love Bug '13
If your doors fit well now, be careful not to clamp too hard. It can change the plane of the cabinet where it meets the cabinet door.
Good luck on your project.
Why do I have to learn everything the hard way?
Cat
Cat futrell is offline   Reply With Quote
cabinet doors Rarebird Modifications, Alterations and Updates 15 12-07-2008 10:05 AM
Overhead cabinet Nina E. Problem Solving | Owners Helping Owners 4 06-02-2007 01:49 PM
cabinet doors, Do we replace them? Ryan Kennelly Modifications, Alterations and Updates 26 05-29-2006 08:45 AM
Cabinet Support Steve L. Modifications, Alterations and Updates 2 11-15-2005 11:06 AM
cabinet latches Legacy Posts Problem Solving | Owners Helping Owners 0 06-01-2003 11:37 PM
