01-14-2017, 11:05 PM
Trailer: Escape
Removal Underneath Porch Light
Hey all. I'm Tim, an Escapee living in my Escape fiver full time for about a year now. Have a question about that gunk behind a porch light. The light needed complete replacement (casing and all). After removal, the substance that the manufacturer uses to seal is clear, thick, and harder than @#$%. I'm worried about scratching fiberglass and removing gel coat if I go at it with a scraper. Any tips? Or any links...because I'm sure this has come up before.
And another thing...when I re-attach the light, I'm almost certain I'll need some type of filler back in the holes. Suggestions?
Many Thanks,
Tim
01-14-2017, 11:12 PM
Trailer: Former 13’Scamp, now Snoozy
I don't know about what to use to remove the "sealant" behind the light, but perhaps Escape factory could give you advice. I would use butyl tape behind the light to seal the wire holes.
Dave & Paula
01-15-2017, 06:04 AM
Trailer: Boler 13 ft / Casita FD
HI Tim...just in from the Think Tank (AKA my hot tub) and have to wonder if that porch light was worked on before?
Your discription of it being 'HARD AS ....' makes me think maybe sombody used an epoxy/fiberglass fillet to stick the light in place.?.
If so you will need to sand it down to where you want it.
As stated many times on FGRV do not use a silicone base product to fixl any gaps as it will leave an oily film, will fail, and make any future repairs all the harder.
01-15-2017, 10:17 AM
Sealer?
Hi,
Agree with other posts. Butyl tape would work well.
Sometimes I just use it around screw holes to make
sure no water enters. Around wires I use a product called
Coax Seal. It is a tar-like product that is easy to work
with your fingers and never hardens.
https://www.amazon.com/Coax-Seal-Moi...ords=coax-seal
Less than $20 will get you lifetime supply....
Seal rolls in sandwich bags for long shelf life.
Share some with your friends?
Larry H
01-15-2017, 11:45 AM
Trailer: 1976 Trillium 1300
New Brunswick
Hi Tim ,If the stuff is clear & hard it's no doubt epoxy. If the "stuff" was applied over the gel coat and not on a sanded surface you my be able to try a flat blade screwdriver and tap on the edge and see if the "stuff" will release from the trailer surface. Hard epoxy can be chipped away if you work slowly. A sharp wood chisel may work too by holding the flat side on the trailer shell as you tap it to break the bond.
01-15-2017, 12:02 PM
Trailer: 13 ft Scamp
Any chance it will soften if you tried gently heating w/ hairdryer
It might soften just a thought
01-15-2017, 12:08 PM
If you go here:
Escape Trailer Owners Community
You will find yourself with the search results on the Escape Forum for discussions about Proflex, which I suspect is the material you are asking about.
01-15-2017, 12:16 PM
Trailer: Escape
Dave & Paula
Thanks David,
I emailed them to ask. I'll look into the tape.
Tim
01-15-2017, 12:20 PM
Trailer: Escape
The light worked fine, and it appeared to be original to the RV. Nonetheless, it could have received an overzealous repair.
Thanks for the silicone tip.
Tim
01-15-2017, 12:30 PM
Trailer: Escape
Originally Posted by Larry C Hanson
Hi,
Larry H
I will look into both. It seems to me this is a case where less is more. You want just enough seleant so water does not enter the screw holes or small electrical hole. What was in place was overkill.
I think I'll try the hair dryer fix first, but my guess is that it may come down to what you suggest.
Yes, I'm gonna try this. Thank goodness I'm at my Mom's and she has one because I don't have enough hair for one.
If you go here:
Going to look now. I knew someone would know how to find this info somewhere on this vboard. Thanks Glenn
To all you folks, thank you kindly. I'll report in on what I finally did to finish the job.
Tim
01-15-2017, 01:46 PM
Trailer: Trail Cruiser
I suspect someone has worked on this before. Sounds like an epoxy resin which may be difficult to work with. Is it something you can leave in place? Personally, I would grind it out and resurface the area but wouldn't recommend this unless you have experience doing this sort of work.
01-15-2017, 04:32 PM
Trailer: Escape
As it turns out...hair dryer's work!
A hair dryer softened it enough so I could peel it off carefully with a plastic scraper and a window blade scraper.
As a youngster, I worked for a guy who taught me how to use blade scrapers to remove paint overspray on cars. I took me awhile to remember about it. Anyway, it's a matter of sharpening (or smoothing out) the scraper on a window by honing it like a knife, then carefully use it to scrape the substance off. It's a matter using an almost flat angle.
It took some elbow grease and acetone to get the last of the gunk off.
I used 3M sealant (5200) because the local big box had no butyl tape or proflex. The label stated that it was safe to use on gel coats...and it is an area that is unlikely to ever see the light of day. The main concern was waterproofing.
Thanks to all for the tips.
01-15-2017, 08:42 PM
3M 5200 is permanent, unlike butyl tape that can be taken apart years later. If you have already used the 5200, you will have a very difficult if not impossible time changing the fixture later. Don't get me wrong here. I use 5200 some times but it is permanent. It is sold as an adhesive-caulk and it is very good in some applications. Butyl tape is easy to work with and clean up afterwards and would be the way to go with a light fixture.
01-15-2017, 09:00 PM
Trailer: Escape
Yes, you are correct, and many thanks for pointing that out.
Lesson learned for next misadventure.
I did find this article on removal. Nonetheless, I will hope and pray the fixture has a long life.
