Removeable water tank? - Fiberglass RV
Old 02-07-2013, 01:01 PM   #1
Trailer: 1973 Love Bug '13
Has anyone used a portable water container and a hand pump to route water to the counter top sink? A friend recently gave me a hand pump - I usually take a 5 gallon square water container with a spout when I tent camp. Any reason I can't run a line from the hand pump to the portable water reservoir with a check valve in the line to pump water to the sink?
thanks
Cat
Cat futrell is offline   Reply With Quote
Old 02-07-2013, 01:04 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Cat futrell View Post
........Any reason I can't run a line from the hand pump to the portable water reservoir with a check valve in the line to pump water to the sink?
thanks
Cat
Nope. It should work fine.
Old 02-07-2013, 01:05 PM   #3
Thanks Tom.
Old 02-07-2013, 01:10 PM   #4
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
When I bought my Scamp, the water tank had been removed. I mounted a 4 gallon 'jerry' type plastic water can under the sink. The handpump hose goes in the top. And it's easy to lift out to fill.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 02-07-2013, 01:11 PM   #5
Good to know, thanks Dennis
Old 02-07-2013, 04:55 PM   #6
Trailer: 1999 casita spirit deluxe 17 foot
Thats how i work mine no problums.I dont use a check valve
greendragon is offline   Reply With Quote
Old 02-08-2013, 05:44 AM   #7
Ian G.'s Avatar
I use an external water container that feeds an electric water pump. You could use the exact same set-up for a manual pump
It uses brass quick connects which make it very easy to use.
Works excellent.
Old 02-08-2013, 06:07 AM   #8
Thomas G.'s Avatar
Works excellent.
Sweet, even insulated. You could have hot or ice water.
Old 02-08-2013, 06:25 AM   #9
Ian G.'s Avatar
Yes a block of ice keeps it cold for several days
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 6 05-20-2011 08:19 AM
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
