Removing carpet glued to floor?? - Fiberglass RV
Old 05-29-2012, 05:26 PM   #1
dylanear's Avatar
Trailer: 2001 Scamp 13'
Not sure if this was the previous owner, or the factory, but the tan carpet in my 2001 Scamp is glued to the plywood floor in places. I've already pulled up the carpet under the bed/dinnette and there are significantly large patches where the foam insulation/backing bonded to the the carpet has left behind significant amounts of foam glued to the the plywood. I have some Allure ordered and will be replacing the carpet, but I want it to lay flat on the plywood without bumpy foam bits under it?
Is there some secret to getting that off there? A solvent that won't stink forever? An abrasive that won't make a mess?
dylanear is offline   Reply With Quote
Old 05-29-2012, 05:36 PM   #2
Robin G's Avatar
Trailer: 2007 Casita
I would be careful with solvents, only cause your dealing with plywood.........
I tore out the carpet in our Casita. What a chore! You would have thought they were trying to prevent a theft of carpet. Glued all over....... With the Casita it's attached to fiberglass with this rubber stuff on top of it. Anyway, the only suggestion I have would be to scrape, scrape, scarpe!!!!
I guess you could try asking where you purchased your Alllure from if they have any suggestions. But I would be leary of using any solvent on plywood.
Get your scraping on!
Old 05-29-2012, 05:47 PM   #3
jen b's Avatar
Trailer: 1980 13 ft. burro
I suggest a dremel tool with a scraping attachment. If that exists. Surely something like that exists?
jen b is offline   Reply With Quote
Old 05-29-2012, 05:59 PM   #4
Raz
Raz's Avatar
I would try a heat gun/hair dryer to soften the glue and a putty knife. Then a sander to get the residue. Watch the sander near your fiberglass. Raz
Old 05-29-2012, 06:33 PM   #5
2yax2go's Avatar
Trailer: Escape 21
South Carolina
When we pulled up the carpeting in our Scamp Mr. 2yax used a Harbor Freight Multi-tool with the scraper blade on it and then went over it with the sanding blade attached. It made a swift neat job that was otherwise entirely messy. (face mask required...should have worn one when we pulled up the dust laden carpet to begin with...ugh.)
Happy Scamping
Josie
"Not all those who wander are lost." (J.R.R. Tolkein from Lord of the Rings..."Strider's Poem")
2yax2go is offline   Reply With Quote
Old 06-01-2012, 12:14 AM   #6
Trailer: Boler 1700
Same thing in my Boler. I bought a paint roller scraper. It is solid steel and doesn't flex. I used a file to sharpen it a LITTLE. You don't want it too sharp or it will just cut into the flooring. Dust mask for sure. Once it was done, I put down a thin rubber underlay tacked down with carpet tape, and then carpet, also with carpet tape. Nice warm floor now.
Fiberglass Gregg is offline   Reply With Quote
Old 06-01-2012, 08:14 AM   #7
Trailer: scamp 13
yep,,,those vibrating multitools would be perfect for this. in essence a miniature version of the profesional tile remover which sort of looks like a floor buffer with a foot wide scraper blade, used for removing old floor tile.
same principle.
Old 06-01-2012, 09:50 AM   #8
Trailer: 1978 Trillium 4500
I used my power sander with a course 80 grit paper and a vacuum attachment to remove the excess glue and residue.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 06-01-2012, 11:12 AM   #9
You can get a really great Heat Gun at Harbor Freight for less than $15 and the scraping tools to go with it for even less. I use the $13 one.
Heat Gun - Harbor Freight Tools
Old 06-01-2012, 01:17 PM   #10
I did mine to a nice clean finish with nothing more than a good sharp putty knife.
Removing the rotten section of floor BigMike Problem Solving | Owners Helping Owners 2 05-10-2011 03:52 AM
Removing Casita floor carpet and have a question about Robin G Problem Solving | Owners Helping Owners 7 05-19-2009 02:00 PM
carpet needs to go Ricky 4 Problem Solving | Owners Helping Owners 3 07-11-2008 05:50 AM
Removing 1982 Burro from trailer to replace floor Legacy Posts Problem Solving | Owners Helping Owners 15 07-10-2008 09:10 PM
new carpet Terry G. General Chat 2 11-13-2006 10:15 AM
» Trailer Showcase
boler
Robin P
70 Scamp
Jay B.
