Removing Coleman Furnace - Fiberglass RV
Old 11-30-2008, 06:17 PM   #1
Don N's Avatar
Trailer: 1997 Bigfoot 25B21RB
I was reading an older post from back in May on the fiberglassRV forum where a member wanted to remove the furnace in his Trillium. I have done a search on this forum but have not had any luck finding out the information or if somebody could link me up to where it has been discussed before would be very helpfull. I started on mine yesterday as I want to get better access to the wiring running front to rear. I have removed the outer "trim" around the furnace with a couple of smaller screws and then 4 larger screws around the outside that hold the furnace into the fiberglass. Also disconnected the gas line into the unit. It doesn't budge now. My outer back cover is riveted to the outer skin so I didn't want to start taking out rivets if it is not going to help me. Was wondering if there was any info about removing these furnaces. The fridge doesn't look any easier to remove either.
Thanks...Don
Don N is offline   Reply With Quote
Old 11-30-2008, 07:12 PM   #2
Flygal's Avatar
Only thing I have to say is my heater (out of my scamp trailer) was bolted to the floor as well.....lucky for me I had access from the cupboard door beside it but I thought I would mention this to you......hardley helpful as far as a "how to"....but more of a here is what happened to mine
Thanks...Don
Flygal is offline   Reply With Quote
Old 11-30-2008, 07:14 PM   #3
Well there's this one Remove furnace written by Patricia Baxter
Maybe something in the Document Center will help?
Furnace Manuals. But, I bet a Trillium owner will jump in to give you guidance!
Old 11-30-2008, 07:28 PM   #4
Don N's Avatar
Donna, is that the correct link? It comes up about the Trillium sink. There is a little bit about the furnace, only a couple of lines. Does Patricia have all her notes on a seperate site?
Thanks..Don
Old 11-30-2008, 07:34 PM   #5
No Don, that's what I found. What I wanted you to notice was:
"removing the old furnace took about 10 minutes to find all the screws and another 10 to actually wiggle the front off the back and remove it. "
Unfortunately that's it and in checking Barbara hasn't been logged into FiberglassRV for more than two months and her e-mail is set to private.
Old 11-30-2008, 07:38 PM   #6
Hummm, maybe Daniel can help the next time he logs in? Trillium 1300 Furnace removal
Old 11-30-2008, 09:07 PM   #7
Harry Young's Avatar
Post
If my middle age memory still works this unit has a tricky exhaust air intake combination telescoping tube typical for its era...Its the same set up as the old Acorn Scamp models, The screws also need to be removed on the outside of the coach and the tube assembly should slip out freeing up slack for the inside assemblies release...Some evil installers used sheet metal screws reachable thru the cabinet works locking the telescoping flue together making it ridgid...These screws were to lock the tubes together and I have found in more than on one job a screw run straight thru the back of the outer shell just off the heat exchanger into supporting cabinet works. Please let me know by posting what you find as I am now curious? The furnace is sandwiched using the flue and the outer wall tensioned against the cabinet.
Harry
Thanks...Don
Old 11-30-2008, 09:19 PM   #8
Don N's Avatar
Harry
Thanks Harry. I was hoping to not have to drill out the rivets holding the back screen in place on the outer wall. But it makes sense with what you are saying, I was just trying to convince myself that I wouldn't have to do it this way.. Maybe next weekend if it gets a little warmer and stops snowing any time soon...
furnace
Coleman furnace Tim R Parts: Buy | Sell | Trade 1 07-22-2013 09:57 PM
Orifice for a Coleman furnace Tim R Care and Feeding of Molded Fiberglass Trailers 11 09-23-2012 09:15 AM
Removing the Furnace Plate Nicole M. Problem Solving | Owners Helping Owners 3 03-13-2007 06:40 PM
Coleman ST-200 Propane Furnace for sale Gord Plowright Classified Archives 0 09-14-2006 12:27 AM
Removing Refrigerator & Furnace Faith Problem Solving | Owners Helping Owners 6 02-03-2006 06:13 PM
