removing DECALS - Fiberglass RV
Old 06-18-2009, 04:09 PM   #1
Trailer: 1973 13 ft Compact II
...some old decals? Can I use a straight edge or should I use some type of plastic scraper with acetone?
I also would like to know if anyone can give me the pitfalls of putting on new, factory purchased decals...
I APPRECIATE your help!!!
BB
bbuehler is offline   Reply With Quote
Old 06-18-2009, 04:12 PM   #2
CarolnJim's Avatar
Trailer: 2002 17 ft Casita Liberty Deluxe
We found that a hair dryer worked ...
CarolnJim is offline   Reply With Quote
Old 06-18-2009, 06:27 PM   #3
BB
Do tell Barbara, where are you going to find "factory purchased decals" for a 1973 Compact? Or is this for some other trailer??
Carol is right, use a hair dryer. And a PLASTIC knife... it won't cut the gel coat like a razor blade or other metal implement ... if you're talking about a molded lightweight fiberglass RV ??
Old 06-19-2009, 06:18 AM   #4
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Heat gun
Old 06-22-2009, 05:54 PM   #5
Thanks EVERYONE!...even the enigmatic Kevin K (AKA: Mr. Heat Gun)...Kevin, I tried to email you on another issue for your advice, but you don't accept emails on your member site.
What's up 'Bro?!
I'll try not to bother everyone too MUCH!!! Promise.
BB]
Old 06-23-2009, 05:52 AM   #6
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I will check and see whats wrong with my email.
Old 06-23-2009, 08:04 AM   #7
US
also googone might help once you start an edge.
Old 06-24-2009, 04:30 AM   #8
james kent's Avatar
Trailer: Boler 1984
That old faded 'Patriotic Flag' on the back of the trailer looked a little excessive since I just got a new spare tire cover complete with mfg name and NEW shiny bright 'Patriotic Flag'. Yesterday I took the old heat gun and, keeping it moving so as not to burn anything, I removed said decal in just a minute or two. A little buffing to get rid of the dirty outline and we're ready to apply a great little bumper sticker or two when found.
Old 06-24-2009, 06:35 AM   #9
Alf S.'s Avatar
Hi: Jim... I still have one left, Red on White, that says
" I go where I'm towed too!".
See you at EM. on the 9th.
Old 06-27-2009, 12:37 PM   #10
Con
Trailer: 1977 Boler 1300/2003 17' Bigfoot
A trick for applying new decal I learned years ago in the body shop. A little liquid soap in a pan of warm water. wet the area down with it, peel the backing of the decal and lay it on the soapy water till it is were you want it and use a squeegee to work the water out. Done
I have done that on snowmobile decals and car decals. The real winner is the Firebird decal on the hood of the Firebird car.
Con is offline   Reply With Quote
Old 06-27-2009, 12:56 PM   #11
Trailer: Bigfoot 17 ft
Fraser Valley
use a heat gun, but you don't want to overheat it too much. Also get a citrus based solvent spray, like LPS Presolve to remove any decals. Presolve & a little bit of heat. No scrapping required. Spray the Presolve, use some heat.....spray some Presolve, use a little heat. Works very well. I also use plastic razor blades to get real nasty hard old decals off, but that's only after they've been saturated in Presolve. No residue. Presolve removes any gummy residue. Very good product, LPS Presolve for removing gum or any glue residue.
DwayneR is offline   Reply With Quote
Decals Add Personality stephanie reed Modifications, Alterations and Updates 11 10-29-2009 07:20 AM
Burro Decals Scott B. General Chat 8 07-29-2009 05:19 PM
Removing Decals Chris and Ame Problem Solving | Owners Helping Owners 3 05-05-2007 08:46 PM
Map Display Decals Frederick L. Simson Modifications, Alterations and Updates 6 04-14-2006 09:58 AM
Manufacturer's Decals Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
