Removing double sided tape. - Fiberglass RV
Old 03-20-2017, 11:02 PM   #1
Zachs's Avatar
Trailer: formerly: 1972 Hunter Compact
I am looking to remove double sided tape on the inside (latex painted walls) of my fiberglass Compact Jr.
The previous owner stuck carpeting on the walls via this tape (pic attached) which I've removed.
Do any of you have ideas on what products I might use that are safe for this trailer?
I need to get rid of this glue.
Thanks in advance.
ID:	104172Click image for larger version
Zachs is offline   Reply With Quote
Old 03-21-2017, 03:33 AM   #2
Raz
Raz's Avatar
I've had sucess by heating with a hair dryer and removing the tape with a small scraper. On gelcoat I use a plastic scraper to protect the finish but here metal will work fine. Push the end of the tape while applying the heat. It should lift off easily. For residual adhesive, try Goo Gone. Be patient and let it work. It may take several applications but it will do the job. Acetone is quicker but the fumes are nasty. I suspect some of the latex paint will come off too. Not to worry, as you will want to insulate and apply a new covering to avoid condensation. Wear gloves to avoid the fiberglass splinters. They're nasty. Good luck, Raz
Old 03-21-2017, 02:10 PM   #3
Trailer: currently shopping
Kentucky
removing doubled sided tape
wd-40 has usually worked for me without damaging underlying materials. i have been using this for about 50 years. let us know how you come out. michael
michael ford is offline   Reply With Quote
Old 03-21-2017, 03:44 PM   #4
Jim Bennett's Avatar
Toluene works great at removing glue residue.
I have used it lots for cleaning off of plastic and metal. When gluing accessories onto an inflatable boat it is used to clean the surface well. I would do a small test spot on paint though, as toluene is often used as a solvent in paint and may take it off too. I have never used it on paint myself. Maybe I will run out to the shop and give it a test.
Also, provide good ventilation and use with rubber gloves.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 03-21-2017, 11:00 PM   #5
Trailer: Coachman
Maryland
Removing Tape
Dab the tape to be removed with a new piece of tape. Will need quite a few dabs to get the old tape to start to release and then gets easier/more effective. As the dabbing piece becomes clogged or covered use a fresh area. This technique has worked every time I have used it. Works on pile fabrics also. Have never tried it on VHB type tape.
MDM54 is offline   Reply With Quote
Old 03-22-2017, 07:03 AM   #6
This is basically what using a solvent does, as what you describe uses the solvent in the tape to soften the old adhesive. New adhesives have these solvents (like toluene) in them to keep them soft and pliable, and they evaporate over time.
2017 Escape 5.0 TA
Old 04-11-2017, 12:41 AM   #7
Trailer: Hunter compact jr
Chaz, what are you covering the walls with once you remove the tape? We removed glue with an electric scraper on our compact and looking for ideas. It had shag carpet on the walls, yuck.
Mcmari is offline   Reply With Quote
Old 04-17-2017, 11:22 PM   #8
Zachs's Avatar
Hi. I'll probably just keep the walls painted off-white. If I do decide to do some winter camping in Oregon I may switch it up. Do you have plans for your walls? Also, thanks for the tip.
vin
Removal and clean up of 2 sided sticky BatDude Problem Solving | Owners Helping Owners 6 04-05-2016 03:04 PM
Found my hard sided tent. The Minimalist Hi, I am.... 14 06-16-2013 08:36 AM
NC | Apache Hard Sided Pop Up In North Carolina casita90 Classified Archives 2 05-02-2012 09:35 PM
Is There a 2 Sided 110 Plug In Out There? barryra Problem Solving | Owners Helping Owners 9 05-09-2011 02:14 PM
MPG: Egg vs Conventional hard sided TT and Hi-Lo types Kip K. General Chat 16 08-27-2007 06:20 PM
