Removing Dustcaps - Fiberglass RV
Old 10-23-2015, 04:58 PM   #1
Removing Dustcaps
Need to know how to remove the dust caps to check Bearing Grease on 80 Boler.
immrbill is offline   Reply With Quote
Old 10-23-2015, 06:13 PM   #2
Trailer: 1999 Casita 17' SD
Ohio
Take a thin screw driver or flat cold chisel and gently tap it in the seam around the dust cap and hub working your way around until it comes off.
Some clean it well and apply a coating of silicon when putting them back on.
Joe
Old 10-23-2015, 06:28 PM   #3
Thank You. Getting ready to hit the road 1st week of November and wanted to check wheel bearings
Old 10-23-2015, 06:43 PM   #4
Just taking off the dust cap off to inspect won't do the trick. You need to remove the retaining nut and remove the hub for inspection and repacking. Don't forget new seals as well.
vin
Removing windows Legacy Posts Problem Solving | Owners Helping Owners 3 06-18-2003 01:53 PM
Removing center trim? Legacy Posts Problem Solving | Owners Helping Owners 16 06-09-2003 06:41 PM
Removing Casita Benches Legacy Posts Problem Solving | Owners Helping Owners 8 04-30-2003 04:08 PM
Removing pop rivets... How?? Legacy Posts Problem Solving | Owners Helping Owners 4 04-29-2003 07:13 AM
Removing trailer battery for winter Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 12-14-2002 04:48 PM
