GooGone, Oops and similar products can damage the finish on certain kinds of plastic and wood finishes. I would test it first. Same with any acetone products.
Acetone is a preferred solvent on gel-coat. It does a great job of cleaning just about anything off of it. Obviously, of course, it also dissolves or mars plastics on contact, so when you use it, make sure you don't splash any onto plastic trim, logos, or striping.
You'll need to determine what base your adhesive uses to figure out what best to use on it. If it's gooey at all, goo-gone, acetone, or another solvent will work well. For a hard, set adhesive your choices may be more limited and a mechanical remover like Kevin mentioned may be your only option. Check your home improvement store for thick adhesive removers that will cling and penetrate the stuff.
If you figure out something that works well, please report back so we can all share it!
Good luck!
Roger
