Old 04-14-2012, 07:30 PM   #1
Trailer: 1980 5500 trillium
removing lights from top back of trillium
does anyone know how to remove the lights on the top back of a trillium, there doesn't seem to be any screws.
Art LC is offline   Reply With Quote
Old 04-14-2012, 09:28 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
might they be rivited on????
Old 04-15-2012, 06:31 AM   #3
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Art, I think you will find they are riveted on, you will have to drill out the two rivets in each light, and when you put new ones back in, re-rivet.
be very careful if you have to pull down the roof liner, it tends to leave th foam backing stuck to the trailer, and dosen't re-glue very well.
use a 1/4 inch or thereabouts bit to drill the head of the rivet of in the light fixture base, then remove the tail of the rivet from inside the trailer
Joe,
Old 04-15-2012, 04:39 PM   #4
Joe, Do I have to re-rivet them on or can I just re install them with stainless screws and nuts, the reason i am removing them is because they are leaking water into the trailer, there must be some kind of gasket between the lights and the fiberglass (cannot tell due to all the silicone on them). can I make these gaskets myself out of rubber?
Old 04-15-2012, 06:47 PM   #5
You can always use butyl putty tape Art....
Double Yolk
1988 16' Scamp Deluxe
Old 04-16-2012, 01:17 AM   #6
Roger C H's Avatar
Question Picture please
I don't know what you are talking about. Inside lights or outside lights. Trilliums didn't come with lights on the top back I don't think. So maybe you have a mod by a PO.
Old 04-16-2012, 05:07 AM   #7
Roger, Art has a 5500 and I think that model DID come with 2" (or so) round lights on the top rear right from the factory.
Double Yolk
Old 04-16-2012, 05:46 PM   #8
My 5500 has 5 lights across the top rear outside, 1 on each outer corner, and 3 centered above the rear window. Mine are the standard oval type lights typical for markers in the 70/80 era.
I do not think mine ever had a gasket, just a bit of putty tape around the hole for the wiring.
I think rivets were used because they don't work loose like a nut and bolt might.
Joe
Old 04-16-2012, 11:59 PM   #9
Roger C H's Avatar
Okay. I stand corrected. Didn't know 5500's were that wide!
I hope he means replacing not removing. If the trailer is 80" wide or wider, 5 lights are required:
http://www.dmv.ca.gov/pubs/vctop/d12/vc25100.htm
lights, trillium
Removing Trillium Escape Window Francesca Knowles Problem Solving -- Owners Helping Owners 4 07-10-2011 07:34 PM
Removing counter top, Bigfoot 17? pindraak Problem Solving -- Owners Helping Owners 3 03-30-2011 10:41 PM
Removing the bathroom in my 78' Trillium 4500 Gumpit Modifications, Alterations and Updates 19 11-30-2010 07:05 PM
Front top bunk on Trillium 4500 James Cooke Care and Feeding of Molded Fiberglass Trailers 3 05-13-2010 11:15 AM
Reverse lights dont work on the back of trailer McClure Problem Solving -- Owners Helping Owners 4 08-22-2006 06:46 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
