Removing rust on stove and fridge? - Page 2 - Fiberglass RV
Old 03-26-2013, 08:35 PM   #15
jlbails's Avatar
Trailer: Boler 1977
Wanted to let folks know that I had great success with Bar Keepers friend last weekend. Rubbed a little on the stove, unpainted chrome (and will stay that way). BKF worked like a charm. It easily removed the red rust specks and got all but the deepest rust spots. Came out nice and shiny. Then I took it to the fridge (painted)-once again all minor rust discoloration came right off with a little elbow grease. I kept going to the 30 plus years of rust on the hinges, and of course cleaned those up too. After I just wiped it all down with a wet rag. The only place it didn't do so well is the metal heater. Love the fact that I can use this stuff inside and out. Gloriously removes the black streaks and oxidation on the fiberglass without resorting to harsh chemicals. Thanks for the tip! Now on to that leaky kitchen window.
jlbails is offline   Reply With Quote
Old 03-26-2013, 08:48 PM   #16
Trailer: Bigfoot 1981 Trailer
Jamie, glad to hear that you, too, have found BKF very helpful as most of us have used this product as well. With your leaky window, suggest you remove it, put in butyl tape, reinstall and no more leaks. I actually overkilled by putting in a very high grade caulking, not silicone, on the outside of the window frames as well.
Old 03-26-2013, 08:52 PM   #17
jlbails's Avatar
Trailer: Boler 1977
Yep, that's the plan. Just need a sunny day and an assistant who knows what they are doing!
Old 03-26-2013, 09:03 PM   #18
Glad to hear that your are going in the right direction.....as someone else reported recently, when putting the exterior window in place, wet the butyl tape with water so you can move it around while the person in the inside lines up the screw holes....I did not do this, and had a somewhat difficult time lining it up. Good luck..Jim
fridge
For Sale: double sink/coleman oven-stove/stove vent/dometic fridge 3way jrocmagoo Parts: Buy | Sell | Trade 3 03-16-2013 03:38 PM
Removing a coleman 3 way fridge KenandJaney Care and Feeding of Molded Fiberglass Trailers 6 06-04-2012 10:32 AM
Removing the stove. IanWR Care and Feeding of Molded Fiberglass Trailers 7 04-22-2011 09:01 AM
How to clean rust spots on stainless steel stove cover and oven door LeeAnne Care and Feeding of Molded Fiberglass Trailers 7 09-12-2009 07:09 AM
Removing Oxidation and Rust marks on fiberglass DavidS Problem Solving | Owners Helping Owners 8 09-04-2009 03:21 PM
