Removing rust on stove and fridge? - Fiberglass RV
Old 03-18-2013, 08:43 PM   #1
jlbails's Avatar
Trailer: Boler 1977
I am wondering if anyone has an easy (cheap, non-scratch) way to remove those little rust spots on the stove top and the fridge trim. The stove is metal, and the fridge is white. I thought about SOS pads, but don't want to scratch it all up, just need to touch up the surface without painting. Any suggestions? Would white vinegar work? Thanks!
jlbails is offline   Reply With Quote
Old 03-18-2013, 09:01 PM   #2
Try some auto wax or rubbing compound on the fridge, maybe it'll work on the stove too. A wax with a cleaner in it would be best. Maybe Mothers mag polish would work on the stove, I use it on our aluminum teardrop.
Old 03-19-2013, 09:25 AM   #3
cpaharley2008's Avatar
try Nev-R-Dull, I used to use on my Harley, shines and polishes, also good for silver and other metals, brass, Barkeeper's Friend is another polisher/cleaner.
Old 03-19-2013, 09:57 AM   #4
Mouse's Avatar
Trailer: U Haul CT13
Naval jelly removes rust.
I'd use it on the stove then wash it off and repaint with a rust protectant, high temperature paint.
For the fridge I would try a polish first.
Mouse is offline   Reply With Quote
Old 03-19-2013, 10:03 AM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You might try a little Bar Keepers Friend dissolved onto a cloth or paper towel. It has oxalic acid and a very mild abrasive to go after rust.
Old 03-19-2013, 11:18 AM   #6
GMike A's Avatar
One more option for you to try is EvapoRust. I use in on my knives that get rusty and have restored many many knives that looked beyond all hope. You can Google it (but its evaporust.com) and then find some. I get my at Harbor Freight and also O'Reiilys auto part carry it here in TX. It wont attack good metal. Soak a rag and let it lay on there. Its an awesome product. I can put it in a gas tank and it just dissolves the rust. Just read their site and see if its applicable to you.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 03-19-2013, 12:37 PM   #7
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Evaporust works great. I was very skeptical. I used it when I did a ground up on my garden tractor.
Old 03-19-2013, 12:53 PM   #8
Trailer: 1979 Scamp 16- side bath
Virginia
Yes- evapo-rust is the way. I first used it a few months ago on the super rusty interior of a moped gas tank I was restoring. After that I found myself literally looking for rusty items around my house/yard just so I could work some more magic!
I've got some light rust on my Scamp fridge that will be treated with it soon.
Ryan P R is offline   Reply With Quote
Old 03-19-2013, 02:09 PM   #9
Brian B-P's Avatar
I assume that this means that the stove is some sort of exposed metal, such as stainless steel, chrome-plated steel, or (unlikely) aluminum.
If the stove has a brushed finish - rather than smooth polished - I would be cautious about any kind of polish.
If the stove is stainless or chromed, some serious surface preparation would presumably be required before painting.
There have been some extensive discussions in FiberglassRV of brushed chrome stovetops, and how to clean or refinish them
Old 03-19-2013, 03:04 PM   #10
If the stove has a brushed finish - rather than smooth polished - I would be cautious about any kind of polish. [quote from Brian]
Good point, without seeing a picture of the actual situation it's hard to determine a solution. I was merely thinking of what I have on hand that I would try, and what I used to clean my own stove. Apparently it's too late to delete my original post, so just disregard it.
Old 03-20-2013, 07:48 AM   #11
Brian B-P's Avatar
I don't think anything should be deleted - they're all good ideas. I was just adding something to think about just in case the stove finish is brushed.
Old 03-20-2013, 09:30 AM   #12
jlbails's Avatar
Trailer: Boler 1977
Thanks everyone. I'll look for evaporust around here, but I do have Bar Keepers friend, so will give that a go first.
Old 03-20-2013, 09:52 AM   #13
Mouse's Avatar
Bar keepers friend will put down a layer of wax that will make it difficult to use evaporust later.
Old 03-20-2013, 07:03 PM   #14
Trailer: 1971 hunter compact jr
If its chrome try ketchup and aluminum foil old hot rodders trick sounds funny but it works then u can polish over that ... but it dnt work on painted stuff
frankie is offline   Reply With Quote
fridge
Removing a coleman 3 way fridge KenandJaney Care and Feeding of Molded Fiberglass Trailers 6 06-04-2012 10:32 AM
Removing the stove. IanWR Care and Feeding of Molded Fiberglass Trailers 7 04-22-2011 09:01 AM
How to clean rust spots on stainless steel stove cover and oven door LeeAnne Care and Feeding of Molded Fiberglass Trailers 7 09-12-2009 07:09 AM
Removing Oxidation and Rust marks on fiberglass DavidS Problem Solving | Owners Helping Owners 8 09-04-2009 03:21 PM
