Removing the Furnace Plate - Fiberglass RV
Old 03-11-2007, 02:44 PM   #1
Nicole M.'s Avatar
Trailer: 1981 Trillium 4500
We just bought this trailer in the fall so haven't yet used it. I imagine I might be here quite a bit over the next few months..
There is a screw attaching the front plate to the frame of the furnance opening, but we can't get to that screw.
The front of the furnance has a small vent in the bottom half of the larger full grate, and there is a little handle that should help to remove it. But this little knob doesn't move, so do we just pull it? Or does it slide up and down? If so we need some WD40, I guess, to loosen it.
It looks like we need to remove this small vent in order to get at the screw that holds the big full plate.
Are we on the right track?
Nicole M. is offline   Reply With Quote
Old 03-11-2007, 03:49 PM   #2
Nicole, what's the brand/model of the furnace? Maybe there's a manual in the Document Center that will help
Document Center - Manuals - Appliances - Furances
There's also a Trilliums Manual there...but, I looked nothing in it that speaks to the furnace.
Trailer Brand Manufacturer - Trillium
Old 03-12-2007, 05:49 PM   #3
Nicole M.'s Avatar
It is a Duo-Therm 65810 model.
This particular model is not in the documents section, so we had a look at the Trillium manual. It looks like the prior owner had the grate on upside down, so that's why it was hard to remove.
We used a screw driver to pry it out, so now we are OK....
Thanks for the help!
Old 03-13-2007, 06:40 PM   #4
Al V's Avatar
Trailer: 2005 17 ft Casita Freedom Deluxe
Send a message via Yahoo to Al V
it is more then likely rusted together, i ended up destroying the wind guard cap on my 78 trillium. in my cause it had to be done so much soot had built up the furnace just did not burn clean. the outer vet tube is a tube in a tube assembly if that helps at all . if you can force some kind of lubricant between the tubes you might have a chance of getting them to separate .
good luck
Al V is offline   Reply With Quote
furnace
REMOVING a DuoTherm gravity furnace Marv Watson Problem Solving | Owners Helping Owners 5 06-08-2009 05:57 PM
furnace cover - interior grill plate Rick G Classified Archives 3 05-09-2009 10:26 AM
Removing Coleman Furnace Don N Problem Solving | Owners Helping Owners 7 11-30-2008 09:19 PM
Thinking of removing the furnace in my Scamp Bill A Modifications, Alterations and Updates 2 09-20-2008 10:34 AM
Removing Refrigerator & Furnace Faith Problem Solving | Owners Helping Owners 6 02-03-2006 06:13 PM
