Removing the icebox - Fiberglass RV
Old 06-23-2014, 09:16 AM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Removing the icebox
Two screws were easy. The other two are under the door, and the door seems to be held on by two larger, softer screws and I'm concerned about ruining them when I try to remove them. Is there a trick to this that I don't know? I want to insulate the icebox so I have to be able to put it back, can't just ruin the door.
Old 06-23-2014, 10:36 AM   #2
Trailer: 13' Scamp
insulation no worky
Not to poop on your plan, but insulting the icebox is not going to help. The problem with an icebox is that every time you open it, all of the cold air drops out. This is probably the main source of heat gain (cold loss) for the icebox. While a little more insulation may help a tiny amount, it is not going to give you the results you want.
Best of luck.
KevinScamps is offline   Reply With Quote
Old 06-23-2014, 10:54 AM   #3
It isn't really the icebox- I'm insulating the wall of the trailer behind the icebox. It's paper-thin and you can see light through it, and it will make a big difference in the rate of ice melting. (Door is rarely opened so that's not the issue.) I insulated the closet last summer and it made a huge difference that you could feel when you open the door of the closet.
Old 06-23-2014, 10:55 AM   #4
Steve Hilby's Avatar
Trailer: Compact Jr
Do you mean the hinge pins, Bobbie? I screwed one up on Sis' trailer and had to make a new one. Better soak them with penetrating oil for a while before trying to loosen them.
Steve Hilby is offline   Reply With Quote
Old 06-23-2014, 02:16 PM   #5
I guess they are hinge pins but they have a flat screw head. Wouldn't budge and I didn't want to mess them up so the ice box is still in.
Old 06-23-2014, 04:55 PM   #6
Trailer: Compact Jr
Can you perhaps just slide insulation up behind the icebox from below?
Old 06-25-2014, 07:20 AM   #7
That's what I'll probably do- I have the microwave out right now and am debating putting it back or not. I don't use it much. Not sure what I'd put in that space if I don't. Maybe one big drawer where the two smaller ones were, or a couple of slide-in baskets.
vin
13' kitchenette w/sink/stove/icebox/furnace and overhead cabinets Tim M Classified Archives 1 06-29-2008 07:42 PM
Trillium Icebox Drain Tim Ryce Problem Solving | Owners Helping Owners 2 05-23-2008 07:23 AM
Cooling fan for an Icebox? Mike Montville Problem Solving | Owners Helping Owners 8 03-28-2008 04:49 PM
RETRO Icebox remodel bbuehler Problem Solving | Owners Helping Owners 5 12-12-2007 08:36 AM
Replaced my icebox with.... efawcett Modifications, Alterations and Updates 4 11-18-2007 10:52 PM
