Removing Trillium body from frame - Fiberglass RV
Old 11-24-2014, 06:08 PM   #1
Trailer: 1976 Trillium 1300
New Brunswick
Hello
Does anyone have any tips for removing the Fiberglass body from the frame on a 13' Trillium trailer. I want to know if the floor will support the rest of the body if I jack it up using plywood pieces to distribute the load on the floor jack. I must do some welding on the frame and access is limited with the body in place. Any help would be appreciated. Thanks Duane
getaway1 is offline   Reply With Quote
Old 11-24-2014, 07:14 PM   #2
David Tilston's Avatar
There are several threads on this subject:
http://www.fiberglassrv.com/forums/f...ium-57834.html
http://www.fiberglassrv.com/forums/f...ame-29617.html
http://www.fiberglassrv.com/forums/f...ame-66137.html
The bottom is mostly flat. There are six bolts, four in the gaucho, two in the dinette that hold it on the frame.
trillium, vin
Removing body from frame Bcboler Modifications, Alterations and Updates 12 07-19-2017 03:30 PM
Removing Body from frame Harvey9 Modifications, Alterations and Updates 3 06-29-2013 05:16 PM
How do I remove the body from the frame? 1971 Trillium 1300 coalminecanary Modifications, Alterations and Updates 26 06-11-2012 09:41 AM
Bigfoot body shifted on frame... advice? Bruce & Melissa L Problem Solving | Owners Helping Owners 16 08-17-2009 11:01 AM
Removing scamp body from frame Scott Corsaro Problem Solving | Owners Helping Owners 1 07-19-2008 11:24 PM
