Reolacing the upper bunk - Fiberglass RV
Old 06-28-2006, 05:12 PM   #1
Hi...we are new to this forum and are looking for some help. We need to replace the support board, of the upper bunk, in a 1986 Scamp. Any suggestions how to do this? Is this screwed into the frame, or fiberglassed in? Please help us figure this out. Thanks in advance. JoJo
jojo93 is offline   Reply With Quote
Old 06-28-2006, 06:02 PM   #2
Steve DeWeese's Avatar
Trailer: 1978 Trillium 13 ft
Ohio
I'm not sure what a Scamp is like, but on my Trillium the back of the sofa hinge is screwed into the board under the front window. To replace that board you would have to unscrew the lower edge of the front window and it should fall free after your remove the material from the inside. Now if this isn't what your talking about just ignore me and I will go away. Just kidding
Steve DeWeese is offline   Reply With Quote
Old 06-28-2006, 09:12 PM   #3
Well Steve is partially right and since Scamp's don't have a frame that leaves fiberglassed perpendicular to the body.
Did someone remove the one from your Scamp or is it badly damaged? Because this one piece totally supports one complete side of the upper bunk, you'll need to be completely confident in your ability to properly fix/replace the piece. Otherwise whomever is sleeping in the bottom bunk may be injured by a falling bunk and the body in that top bunk.
By the way...WELCOME to FiberglassRV, we're glad you're here
Scamp front seatback/upper bunk mounting Bill White Problem Solving | Owners Helping Owners 5 11-14-2009 04:47 PM
Trillium 1300 Upper Bunk Bed Jeff Y. Classified Archives 0 10-05-2009 11:58 AM
Upper bunk in 76 TM14 Surfside Steve Smith Problem Solving | Owners Helping Owners 2 08-04-2008 03:06 PM
Upper Bunk Completed Christi V. Modifications, Alterations and Updates 3 02-21-2008 08:12 PM
replacing the upper bunk jojo93 Modifications, Alterations and Updates 3 07-02-2006 10:33 AM
