Repair plastic grey water tank? - Fiberglass RV
Old 05-01-2011, 05:58 AM   #1
Trailer: Triple E Surfside
Nova Scotia
My grey water tank seems to have a small leak in it, and I noticed a fiberglass patch kit at the local RV dealer for repairing the plastic tanks for $50.
It seemed to just be fiberglass and resin! (for $50)
==> Anyone know if I will encounter problems if I use conventional ($10) automotive type fiberglass repair kits on the plastic tank?
Rob vanNostrand is offline   Reply With Quote
Old 05-01-2011, 10:40 AM   #2
Trailer: none
Think they make plastic weld kits for repairing plastic,
Hambone is offline   Reply With Quote
Old 05-01-2011, 07:04 PM   #3
Kevin Poll's Avatar
Trailer: 1975 Trillium 13 ft / 2002 Honda Odyssey
I'm with Hambone on this one. it is better to weld plastic (melt it back together using the appropriate solvent) than to bond epoxy and glass on the outside of the tank because the plastic may not flex or expand/contract at the same rate as the FG and the patch may eventually leak.
I would consult with a plastics retailer to determine what kind of plastic (prob PE) and for the best way to fix.
Kevin
Kevin Poll is offline   Reply With Quote
Old 05-01-2011, 08:44 PM   #4
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
"Welding" the plastic is the way to go. If you can easily get to the area of the tank that needs the repair, it should not be too hard to fix.
This would do it: Plastic Welding Kit with Adjustable Temperature
Steve Outlaw is offline   Reply With Quote
Grey or Black Water Tank on 13' Trailer? sj2moncton Plumbing | Systems and Fixtures 4 09-14-2010 05:14 AM
Grey Water Tank Sensor Tamid Problem Solving | Owners Helping Owners 7 09-13-2010 02:06 PM
hole in grey water tank Joseph and Melanie Castine Problem Solving | Owners Helping Owners 5 09-11-2008 12:02 PM
Leaking Grey Water Tank on Boler KevinDR Plumbing | Systems and Fixtures 7 09-01-2007 10:12 AM
