Replace door glass in Compact Jr - Fiberglass RV
Old 05-19-2009, 06:07 PM   #1
Trailer: 1973 Compact Jr
I did try searching but wasn't successful --
The trailer I bought has a cracked upper window in the rear door. I'm trying to figure out how to get the slider out so I can replace the glass.
It looks as though I should be able to just retract the latch pins and the inner window frame would just pop out. So far, looks have been deceiving.
Any pointers of where to look for this info?
Thanks!
Dana T is offline   Reply With Quote
Old 05-19-2009, 06:18 PM   #2
Rick Brown's Avatar
Trailer: Compact Jr
You should be able to push the window to one side and then it should come right out. The frame of the window has springs on one side that hold it in the frame. This is how I replaced my broken glass in my Compact Jr. Please let me know if this works for you
Rick Brown is offline   Reply With Quote
Old 05-19-2009, 06:53 PM   #3
Perfect!
I was trying to slide it to the wrong side. Once you told me about the springs I knew I had to slide the window toward the springs -- the side that looked the "emptiest". The windows popped right out.
Thanks for your help -- now off to Home Depot for the glass and safety chain, KMart for the side marker lights (the contacts of the old ones are too corroded), then I'll be ready for the DMV tomorrow.
Old 05-20-2009, 02:46 PM   #4
This is ridiculous -- I'm still stumped by the window.
I have the window out of the outer frame, and now I need to open the inner frame to replace the glass. When I looked at it last night I thought all I need to do is prise out the L-shaped clips in the corners. I tried prying them out, and also hammering them out with a drift, but made absolutely no progress.
There are 2 dimples in the aluminum frame on either side of the clip, so I drilled out all four dimples that match up to the two legs of one L-clip. After much muttering, prying, and etc. I did manage to get one corner open, but I also broke the L-clip in the process.
So how does one take apart the inner window frame without breaking things?
Thanks!
Old 05-20-2009, 06:35 PM   #5
Rick Brown's Avatar
Trailer: Compact Jr
That is the easiest thing to do.............take it to a hardware store who replaces glass and let them do it. That is what I did $15.00 is all it cost me.
Stained Glass Door Entry Terrance Modifications, Alterations and Updates 4 08-02-2011 01:52 PM
Need to replace windows 1971 Compact jr Tania Problem Solving | Owners Helping Owners 1 06-15-2010 05:41 PM
Stained glass entry door window shane n Modifications, Alterations and Updates 26 08-29-2009 05:23 PM
Need to replace door window scamp 83 - where and how? KarinP Problem Solving | Owners Helping Owners 7 04-20-2009 06:21 PM
Jalousie Window - replace with glass or plexi? Daisy Problem Solving | Owners Helping Owners 7 05-24-2006 04:04 PM
» Trailer Showcase
Trilly
Mgarofalo
Alice
Mr.Stu
