Replace water heater valve? - Fiberglass RV
Old 06-17-2012, 09:51 AM   #1
Trailer: 1977 Scamp 13 ft
Can someone give me detailed instructions to remove and replace an older unitrol gas valve on a pilot light gas water heater? I think it's an old suburban or at wood.
Thank you!!!!!
David Morgan is offline   Reply With Quote
Old 06-17-2012, 12:45 PM   #2
mszabo's Avatar
Trailer: U-Haul VT16
That's an expensive part to replace. What problems are you having?
May be something else less costly.
Old 06-17-2012, 02:47 PM   #3
When it shuts off it still leaks gas out of the orifice and then there is a small unstable fire right at the jet orifice and when it re-opens I have a pretty large fire ball before the fire eventually moves back to the end of the mixing tube. Also the nobs are very stiff. It's a 1969 vintage so I was quite happy it works this good. I have no problem buying a 75$ valve and new pilot jet and thermo couple. It's worth it. I just have no idea how to pull the valve out... Does it unscrew with the thermostat connected on the back?
Old 06-17-2012, 11:45 PM   #4
Perry J's Avatar
If you make a mistake and have a leak it could be life threatening.
Unless you're very handy or mechanically inclined it's sometimes better to pay the money and let a pro do the job.
Old 06-18-2012, 09:32 AM   #5
I assume you mean a LPG leak? I am quite comfortable with fittings and gas lines, I have several leak detection systems that I am well trained in the use of.
All I am asking is how to remove the valve. I have replaced several water heaters, but I have never replaced just the valve. I believe it just unscrews but I want to make sure of this before I go wrenching on it!
Old 06-18-2012, 03:51 PM   #6
My local service center showed me that it simply un-screws with a little bit of muscle required. They have a used unit for $30
Moving on.
Installing cutoff valve in toilet water supply line Fran L Modifications, Alterations and Updates 15 04-08-2015 07:50 PM
Suburban heater - Gas valve question Todd Russ Problem Solving | Owners Helping Owners 1 02-17-2010 09:10 AM
Hot water tank pressure release valve Steve Nentwig Problem Solving | Owners Helping Owners 3 04-08-2007 04:38 AM
Black water valve leak Legacy Posts Problem Solving | Owners Helping Owners 0 04-28-2003 06:19 AM
» Trailer Showcase
Casita
Kevin K
Boler
robeye
