Replaced Window Crank - Fiberglass RV
Old 06-21-2016, 08:33 AM   #1
Trailer: 2005 Scamp 16
When we bought our 1982 Scamp 13 last May, and were towing it home, I glanced in the rearview mirror and saw the panes of our curbside jalousie window lifting 2-3 inches from the frame as we drove. Apparently the window crank was stripped and wouldn't tighten down into a self locking position.
We solved this problem by using duct tape to tape the window closed as we drove, then removing the tape at camp and it just became a part of our routine. Well, duct tape is sticky when it sits in the sun and I decided that I didn't want to do that this season and I didn't need to be afraid of replacing/fixing something on my own.
Fast forward to a few weeks ago, when I decided to order three different kinds of mechanisms from Vintage Trailer Supply and just hope that one would work. SO HAPPY to discover that part number VTS-2001R- Slant Sill Torque Operator-Right was a perfect fit for our window! Removing the old and replacing it took about ten minutes. I don't know what I was afraid of! I've now got new screen on order and will be polishing up the aluminum frames once it arrives and I replace the screens.
Crazy how being able to do one tiny repair has given me confidence that I can do more!! Which is good, because our sink drain snapped off on our last trip, so that's an upcoming repair as well
emij is offline   Reply With Quote
Old 06-21-2016, 09:02 AM   #2
Great job! Those old jalousie windows are sure nice. How is the weatherstripping?
Old 06-21-2016, 09:03 AM   #3
Trailer: 1979 Scamp 13'
Nice fix! I love the confidence I get from fixing something new, too...good luck on the sink!
Zennifer is offline   Reply With Quote
Old 06-21-2016, 09:18 AM   #4
So far, no leaks from either of the side or door windows. We were having an issue with the little window above the stove, so I replaced the shrunken seal that you can see in this photo, with new gray Hehr Standard Glass Seal from VTS as well. That was so easy I actually forgot I did it until just now! And we spent two days in torrential afternoon showers in Steamboat and NO LEAKS!! (also, all of that silicone that you see? That's from the PO. It's on my list to remove at some point!)
Old 06-21-2016, 09:21 AM   #5
Thank you! I feel like I need the well wishes on the sink. Such a weird thing to have happen, but we were on a six mile stretch of HWY 40 on the way to Steamboat where they have the road torn up. It was so bad. Even driving super slow things were bouncing around. Worst road we've been on. Something in the cabinet must have smashed against the drain, snapping it right off!
Old 06-21-2016, 09:37 AM   #6
I think it's a pretty standard part, a little bulb-like thing that functions in place of a P-trap. Should be a straightforward repair. As with a lot of plumbing, getting the old stuff apart (without destroying the pieces you want to keep) and cleaning everything up is the hard part. Be glad you don't have a furnace under the sink!
I'll add my best wishes!
Old 07-20-2016, 06:53 AM   #7
Trailer: Ventura
Manitoba
Ha! I was about tonpost same thing! I have a Ventura but that looks same shape as mine!
And my plastic thing under sink broke too only I'm unshure if broke in storage when gutting trailer,broke gutting or came broke :/ I'm waiting for the local rv store to get that part in yet
Cheyanna83 is offline   Reply With Quote
Old 07-20-2016, 07:02 AM   #8
Good luck on fixing yours! I finally have time to fix it today, so the Scamp is sitting out front, waiting for me to get out there and get to it! Hopefully it's as easy as it seems it should be!
And Jon, I'm VERY glad I won't have to work around a furnace! Not a lot of space to work as it already stands
Old 07-20-2016, 08:25 AM   #9
Trailer: Ventura
Manitoba
I watched a video saying u have to take frme apart to replace the gear...did u have to ???? If I can advoid taking whole bloody thing out be great lol
Old 07-20-2016, 08:42 AM   #10
NO!! One the Scamp, I went to the inside, and the screens in their frames come out in one piece. From the bottom, slide the frame up, as far into the upper lip as you can. This leaves a gap at the bottom and you can then use your fingers or a small flat screwdriver to get under that bottom edge, lift out slightly, and then slide down. The entire frame and screen should come out. I took all of mine out last night, because I'm replacing the screens today, too. I'll take a picture when I get out there this morning and try to get it loaded today, so you can have a bit of a visual, but you shouldn't have to take the frames apart, unless your Ventura is completely different!
Old 07-20-2016, 09:00 AM   #11
Trailer: Ventura
Manitoba
See if pic attached lol tech hates me lol
mine looks simmilar I think
Appreciate the help this been a huge learning path for me lol
Old 07-20-2016, 09:09 AM   #12
Trailer: Ventura
Manitoba
Screens I know how to take out I need to replace mine lol most screens have the mesh duct taped on lol
Video said to uninstall the whole window out of the camper I did that last year don't want to do that agine lol
Funny is when I pulled over to stop Pandora (my camper) flapping like a bird i had a hells angles gain stop and asked if I needed help lol most give them a bad rap but they seem nice! Lol they helped duct tape windows down and off I went agine lol
Old 07-20-2016, 09:11 AM   #13
It looks like you may already have your screens out? So I started by taking out the screws to the torque operator that the crank goes in to. In the middle of the round bar, that goes across, from the torque operator, we had two additional screws.
Take those out. This will allow you to slide the bar and pull it loose from the torque operator. Ours was sticky, so I really had to wiggle it to push it into itself, so yours might be the same.
Replace the torque operator, adjust your bar so it fits correctly (inside of our torque operator and on the bar, were little notches that needed to line up), put the two screws back in the bar, replace your handle and it's done.
I should have made a video because it took me forever to figure that out, but it's really easy once you know. If you more visuals, I'm off to the orthodontist with my girl, but can take a video later and upload it!
Old 07-20-2016, 09:13 AM   #14
We spent all last summer duct taping our window closed! It works! Ha ha! I think I saw those same videos. Maybe I'll make one of my own anyway, just so others can have a clearer idea! I wish I could give you some of the screen I bought. It only came in a 25 foot roll, and with only four windows, I'm not even going to come close to using it all!
window crank replacement video? Scott S. Modifications, Alterations and Updates 2 09-15-2009 02:08 PM
jalousie window crank repair Roy Massen Problem Solving | Owners Helping Owners 10 06-02-2009 06:37 PM
Crank out window question Loretta M Problem Solving | Owners Helping Owners 8 07-30-2008 07:58 PM
SOLD - Small Crank Window Nakita B Classified Archives 2 06-16-2008 11:12 AM
Crank'n'go solar/crank am/fm radio Legacy Posts General Chat 12 09-03-2006 11:12 AM
