Replacement belly band - Fiberglass RV
Old 10-10-2014, 02:00 PM   #1
I have just aquired a 70's boler 1300. Its a real fixer upper and came without alot of the original parts. Im in need of a belly band or place i can buy one.? I would also be interested in any substitutes for the aluminum. Iv tried scamp but they can only ship to canada by cutting the band in 4' sections.
Thanks in advance for any help.
Pat
patdicks is offline   Reply With Quote
Old 10-10-2014, 06:08 PM   #2
Pat another option you might try is what I dd on my love bug and my sons perris pacer which was to belt sand the edge of the belly band as smooth and straight as possible and then apply thin strips of fibre glass over the seam . Then hand sand it to clean up the edges . Then I purchased two rolls of chrome 1/2 inch trim from auto zone about 20 bucks a roll . It is self adhesive and apples easily and stays on very well
Mikmay is offline   Reply With Quote
Old 10-10-2014, 06:23 PM   #3
Ian G.'s Avatar
The standard Boler belly band is just 3/4"x3/4" soft (annealed) aluminum "C" channel. It is easy to bend "gently" as you work it around the trailer. Drill and rivet about every 16".
Old 10-11-2014, 11:04 AM   #4
Ok thanks for the suggestions. The boler has relatively newer paint. So I'd hate to be sanding. I'll have a look in calgary for some C channel. Thanks again.
Old 10-11-2014, 12:18 PM   #5
Ian G.'s Avatar
I am also in Calgary, should be easy to find, try Russel Metals, the longer the lengths you can use the better, originally there was only one join.
Old 10-12-2014, 09:48 PM   #6
Might be easier to find 3/4 Square and saw out the extra wall on a table saw with a carbide blade.
boler
75 Trillium belly band replacement Dezzh Problem Solving | Owners Helping Owners 3 05-21-2012 08:09 PM
trillium belly band Barry Konkin Problem Solving | Owners Helping Owners 3 01-21-2009 04:13 PM
Compact juniors: tape: vertical belly band Kent I Problem Solving | Owners Helping Owners 12 11-25-2008 12:05 AM
Boler Belly Band Sealer Dave Mc Problem Solving | Owners Helping Owners 7 05-09-2008 05:49 AM
HOW DO I RE-ATTACH BELLY BAND Mary Lynn K. Problem Solving | Owners Helping Owners 19 05-30-2006 05:38 PM
