Orginally posted by andy singleton
Beverly,
I finally got the vent for my 1981 Scamp. The store I went through had to order it twice. Although the overall dimensions of the lid were 15 x 22, the order size was 13 x20. The size is based on the hole cutout in the roof for the vent. Here is the part number for my 13 x 20 vent, P/N 60272. I put it on today and it fit like it should.
Andy
Andy and others: I found this hread thru a search. I am going thru the same trouble of having to replace the plastic framed roof vent becuase of cracks and
leaks and it is no longer structurally sound in keeping
fiberglass roof from flexing. My opening appears to 14X21" Not 13X20, nor 15X22. What have others measured on older scamps? I have a 1979 Acorn (Scamp) so i am leaning toward the 13X20 described by Andy. It is about half as much cost as the 15x22. Is this what you found? What replacement size does
scamp sell? I believe Steve at Scamp once told me that they do sell 15X22 vents but apparently they don't fit older scamps, is this correct?
Andy, Whose part # is 60272? Where did you ultimately get your vent? Who manufactured it? Is it aluminum frame or plastic frame? the original one installed in my acorn is plastic. I had done alot of research online previously and had come up with several sources for both sizes but have since lost that info as i wasn't sure what size. The size rating apparently is nominal and is somewhere between roof opening and actual lid size.
Any help is appreciated, any installation tips? Did a new vent also help shore up thesagginess in the roof at this point?
Later - Joe
