Replacing carpet - Fiberglass RV
Old 05-19-2009, 09:08 AM   #1
I am looking at removing carpeting from my 13ft Scamp with some linoleum. I have taken out the bench seats but have never removed the couch or other parts. What did others do when replacing the carpet--did you remove everything or what?
Thank you for help.
Jane
Jane K is offline   Reply With Quote
Old 05-19-2009, 11:06 AM   #2
I actually left my bench seats in, and my front bench in.... I cut the carpet between the two back benches - and put laminate on the floor area....
I'm sure others have done it different ways, but this worked out well for me.
Tim M is offline   Reply With Quote
Old 05-19-2009, 01:06 PM   #3
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
Take the carpet out first. Now make a template of your floor out of paper then lay this on your flooring and cut it out. This will give you a better fit. I left all the bench's in, when you take the carpet out under the table there will be a gap just slide the flooring under that gap. Very easy to do. Take the door sill pate off on the floor from under the scamp, 2 screws If i remember right. On the step up use a section of aluminum angle as trim.
Replacing the carpet in my Scamp Monica M Problem Solving | Owners Helping Owners 2 04-25-2010 09:39 PM
Replacing Overhead carpet strip on 1970 Burro JeremyHammons Problem Solving | Owners Helping Owners 10 03-03-2009 09:16 PM
new carpet Terry G. General Chat 2 11-13-2006 10:15 AM
Replacing seam carpet AbenDeb Problem Solving | Owners Helping Owners 2 08-13-2006 08:25 AM
new carpet Legacy Posts Modifications, Alterations and Updates 15 04-08-2003 08:55 AM
» Trailer Showcase
Daisy
Pomfritz
Casita
Kevin K
