replacing ensolite on Scamp 13 - Fiberglass RV
Old 05-24-2019, 06:28 PM   #1
FL
Hello - who has replaced the ensolite wall covering in their campers? What product did you use? I was not planning to replace my ensolite, but there are several very bad patches, and the rest is not in great shape either.... it's a 1974 Scamp 13 and several windows have leaked in the past, which ruined a lot of the wall covering....
Thanks for any info you have!
Melanie
campermelanie is offline   Reply With Quote
Old 05-24-2019, 07:25 PM   #2
David B.'s Avatar
Replacing all the ensolite is daunting. I would try taking some pieces from under the benches or closets for patching the existing wall material. After a thorough cleaning, use a latex calk to fill all the seams (remove the seam tape first), then using a damp wadded up paper, dab at the calk until the texture matches the ensolite. Paint the ensolite with a latex paint, and you’re done.
OR....You could also remove all interior furniture (cupboards, closets, benches, etc.), then glue a layer of reflectix insulation over the ensolite, tape all the seams with foil duct tape, then glue marine headliner to this. After replacing all the previously removed interior components, you’ll have a new looking Scamp.
OR.....take it to Scamp factory for a professionally looking job.
Best of luck
Dave & Paula
Old 05-25-2019, 12:15 PM   #3
FL
Ok what if I cut out the worst sections, and replace them with the foil ray insulation sold by scamp, then paint everything to match? Do you think that would work?
Old 05-27-2019, 06:17 AM   #4
Jon in AZ's Avatar
No. In my opinion it would look terrible, and painting foil bubble wrap negates its radiant properties.
Agree with Dave. Cut pieces from hidden spaces inside cabinets and benches to patch bad sections in visible areas. Replace cut sections with foil bubble wrap (unpainted).
No need to order from Scamp, BTW. Hardware stores, including Lowe’s and Home Depot, stock other brands of foil bubble wrap, functionally equivalent. Reflectix seems to be the most common.
Once you’ve done all your patching, use paintable latex caulk to fill seams and small gaps and gouges. You can use a crumpled damp rag to approximate the texture of the elephant hide. Then paint.
It would help to know what you’re dealing with- how much and how bad. How about some pictures?
Old 05-29-2019, 12:24 PM   #5
Trailer: Lil Bigfoot 1988 B13.5
In my lil'Bigfoot 13', I used bed liner spray (raptor). I pealed all the existing wall crap back to the closed celled foam. Primed it and sprayed it. It was a task but worked very well. You can search it on here to see what it looked like. It looks good and is holding up very well.
Drtriumph is offline   Reply With Quote
Old 06-09-2019, 08:58 AM   #6
Trailer: Boler
Best of luck
Dave & Paula
How important is it to prime ensolite before pairing with latex paint. Mine looks pretty bad! Prob needs a gentle clean as well ?
Daryl05 is offline   Reply With Quote
scamp
Replacing Ensolite Seams Gerry Problem Solving | Owners Helping Owners 7 11-14-2016 04:36 AM
replacing ensolite Simone Modifications, Alterations and Updates 7 10-19-2015 03:04 PM
Replacing ensolite in Trillium Ken B. Modifications, Alterations and Updates 39 10-16-2012 10:05 PM
Replacing Ensolite Sandi Pitre Modifications, Alterations and Updates 3 09-05-2012 07:22 PM
replacing ensolite jojo Problem Solving | Owners Helping Owners 7 05-06-2010 10:31 PM
