replacing mattress - Page 2 - Fiberglass RV
Old 09-04-2011, 07:54 PM   #15
Trailer: My 4th Trillium
Winnipeg
Well got bored on Sunday after sons football game and had a look at the spring set up under the Bigfoot,this trailer is a single axle model specs are Dry weight 2400 lbs hitch weight 400 lbs tires are 235/75Rx15. When i bought this trailer it was empty other than a few dishes and some pots, I was sitting real low but I knew the tow truck had a 4" lift on it, so it looked like the tail was sitting low anyways. Short story I pulled both wheels and dropped the springs out to find one with a broken leaf. I went to the local PA store they had springs close but not enough weight only rated at 2000lbs i will have to wait untill Tuesday and hit Casterland they have 3500 lb springs.....Now spring over for more height?? for the newer trucks any input????
Craig Broughton is offline   Reply With Quote
Old 09-04-2011, 08:13 PM   #16
Yes, replace the springs on both sides of the axle, shackles and the bushings. See this recent topic by Cam for more info: Bigfoot 5th wheel springs
Old 09-04-2011, 10:18 PM   #17
Lizbeth's Avatar
Craig, don't believe that weight. We have discussed Bigfoot weight before and those weighs are underestimated.
Look on the bottom of the list in post #1 here;
Trailer Weights in the Real World
Our single axle is the first one at 4660 lbs. It was packed for the two of us for a four day weekend. The list does not identify single or duel axle but the dual axle models are heavier than the single.
Old 09-05-2011, 08:16 AM   #18
Winnipeg
WOW!!! If I replace the springs and axle maybe I should go with 6000lb rated
Old 09-05-2011, 08:23 AM   #19
Mike Magee's Avatar
Trailer: Li'l Hauley
If it weren't all disassembled, I would have suggested a trip to the scales to get a better idea.
How to prepare Tofu
Step 2: grill some meat
Old 09-05-2011, 11:31 AM   #20
Lizbeth's Avatar
At least now you can make an informed decision. Real trailer weighs are always a hot topic here because in general they are underestimated. That's why it is a good idea to actually weigh the trailer. With two adults and a couple of kids and their stuff and toys weigh can sneak up real fast.
P.S. hubby though a 5400 lb axle would be about right for a single axle because the hitch weight rests on the truck or landing gears.
Foam Mattress SharonNDean Problem Solving | Owners Helping Owners 5 04-11-2008 03:17 PM
What do you use for a mattress james kent General Chat 6 04-05-2006 06:06 PM
Southern Mattress ssgreg Classified Archives 1 02-27-2006 07:07 AM
Mattress topper Legacy Posts Modifications, Alterations and Updates 0 06-01-2003 09:04 PM
Mattress Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
