Replacing my RV's Decals - Fiberglass RV
Old 05-10-2013, 08:09 PM   #1
Trailer: 2008 Keystone Montana 3400RL
I have a 2008 Keystone Montana 3400RL fifth wheel and the decals are peeling. Keystone sent me decals but won't pay for the installation so I thought I'd look into doing it myself. I have noticed that on the front and back caps the gelcoat isn't as shiney and smooth as it used to be. So I have a few questions:
How would I remove the peeling decals?
How would I revive or replace the gelcoat where it looks dull?
Is there anything I'm missing that I should know?
Thanks
Ron
NASCARon is offline   Reply With Quote
Old 05-10-2013, 08:19 PM   #2
Trailer: 1980Trillium 1300
Thanks
Ron
My opinion as answers for your questions, orderly: Using heat gun to remove decals, labels...To bring back shiny original state, try to buff it with quality compound. Do not over buff, you might burn it beyonds repair. Hopefully it helps.
Old 05-10-2013, 09:27 PM   #3
I'd use an eraser wheel to remove crusty old decals: 3M-7498 STRIPE WHEEL W/ARBOR - Amazon.com
Bottom line, you've landed on a forum for all molded towables, which your Keystone.... isn't.
Maybe you'd have better luck with a forum that has information about your brand of trailer: Keystone Brand at IVR2.com
Best of luck
Old 05-10-2013, 09:29 PM   #4
I just finished taking the decals off of a pop-up I am rebuilding. A heat gun on low heat, good finger nails and a bit of a learning curve as you figure out what angle to peel at, how much heat to use, and how much burned finger pain you can tolerate.
There are some decal release liquids out there, but they don't seem to help much.
Fergot to add: Eraser wheels work well on fiberlass, but will burn painted surfaces.
Old 05-11-2013, 06:11 AM   #5
Why do you say that Donna?
Old 05-11-2013, 06:20 AM   #6
Ron, this forum is an all molded towable forum. Your Keystone is built with a frame and fiberglass panels. You have seams everywhere the panels are attached. All molded trailers are manufactured by using a mold.... more like a fiberglass boat.
Does this help?
Old 05-11-2013, 09:13 AM   #7
Yep, and I don't know of any 34' fifth wheel molded fiberglass trailers either.
(Hint: Keystone 3400 might be 34' or 3.400 meters long, who knows?)
Old 05-11-2013, 04:51 PM   #8
The 2008 Keystone Montana 3400RL is 38 feet 4 inches
Okay I understand what you all are saying now. Thanks for your help.
decals? Donny55 General Chat 2 09-21-2012 12:24 PM
Boler Decals? Brandon G Classified Archives 11 03-01-2011 05:46 AM
Boler decals RogerH Modifications, Alterations and Updates 5 04-25-2010 07:27 PM
Burro Decals Scott B. General Chat 8 07-29-2009 05:19 PM
