Hi folks. I picked up a '76
Scamp about a year ago. I've been slowly working my way through it. I've removed and replaced every rivet. I've removed, cleaned, and re-seated the
jalousie windows, etc.
For my next project, I'd like to address the plexiglass
windows in the front and back. They are both very scratched up, and the seal has shrunk so much I've had to put almost an inch of black vulkem in to prevent leaking during a heavy rain.
Two questions:
Scamp sells the window seal. I assume the seal they sell will be the correct seal for a 1976. Anybody know if this is confirmed, and/or should I buy the seal from some other place?
Second question, I see
scamp also sells replacement
windows. I've also read that others use the existing as templates and just buy plexi or lexan. I'm actually toying with the idea of using a plastics buffing compound like Novus to clean up my existing
windows. Anybody have any experience with this? If so can you advise and share.
Thanks in advance.
Dan in Des Moines
